Do you check your Trolling motor
genxer36
Lord of Tomfoolery
Bethlehem, Georgia
For the cable steer trolling motors.
Do you periodically check the cables?
Make sure the tension is set correctly?
I've had my Minn Kota Edge for 4 years & never thought about checking the cable tension. That was until Friday, when I heard a pop & the pedal would not turn the motor. Good thing it was the end of the day.
Saturday I took the cover off to see how expensive it was going to be.
Turns out I was able to fix this myself. Saving me a long drive to the authorized service center & some $$$.
Apparently the cables where so loose that they were bunching up on the sides. One cable was still attached. The top cable came off the spool & wrapped around the wiring.
The cables should look like this when the correct tension is set:
Left cable in the picture is on the bottom, right is on the top.
