- Apr 27, 2010
- Bethlehem, Georgia
Battery Ratings Note: These are minimum engine specifications. Additional electrical loads from the boat will require larger batteries.
FourStroke Models
9.9/15 & 25
465 Marine Cranking Amps (MCA) or 350 Cold Cranking Amps (CCA)
30/40, 45/50
Operation Above 32�F (0�C) 465 Marine Cranking Amps (MCA) or 350 Cold Cranking AMPS (CCA) Operation Below 32�F (0�C)
1000 Marine Cranking Amps (MCA) or 750 Cold Cranking AMPS (CCA)
75/90
1000 Marine Cranking Amps (MCA) or 750 Cold Cranking AMPS (CCA) Ampere-Hours (Ah) 70 - 100
2-Stroke Models
6 - 15, 20/25, 30/40, 40/50 & 60
75 - 125
525 Marine Cranking Amps MCA) or 450 Cold Cranking Amps (CCA)
V-6 Carb/EFI Models
135/200 & 225/250
630 Marine Cranking Amps (MCA) or 490 Cold Cranking Amps (CCA)
OptiMax Models
2.5L/3.0L
Taken from the Mercury webpage -http://www.mercurymarine.com/service-and-support/storage-and-maintenance/faqs/outboards/?category=electrical
FourStroke Models
9.9/15 & 25
30/40, 45/50
75/90
2-Stroke Models
75 - 125
V-6 Carb/EFI Models
135/200 & 225/250
OptiMax Models
2.5L/3.0L
