- Jan 16, 2009
- SouthEast Arkansas
I am prolly going to open a can of worms here but hey............
Ok here is what I am doing.............the 16ft Laser originally started life from good ole Roarks plant weighing in at a scant 624lbs for hull weight. Well after much and I mean ALOT of searching and talking to go fast guru's and even one SST120 championship holder I have done a little bit of redesigning between the hull and cap. Now mind you this is still going to be used "occasionally" for actual bass fishing. The hull weight should be down to around 450 now...........I dont know actually but this is a purdy good estimate.
Ok knowing this what would some of you if you where doing this project.............. use to power dis bote wit?????????
