Abu Garcia Ike Rod & Reel Combos are Perfect for Serious Up-and-Coming Anglers
Abu Garcia has introduced a new line of ‘Ike’ rod and reel combos tailor made for up-and-coming youth anglers.
While taking part in a virtual conference call as part of ICAST Online, we got the inside scoop from Abu Garcia on these awesome new setups designed for younger anglers who are ready to ditch the push button, and graduate to a more advanced platform.
GEN IKE SPINNING COMBO
Abu Garcia
With inspiration from Mike Iaconelli, the Gen Ike spinning combo offers cutting edge design and precision performance for first time anglers. The Gen Ike platform features quality components paired with aggressive cosmetics and is available in both spinning and low profile baitcast options. Each 2-piece composite blank is fitted with high density EVA split grips for lightweight comfort and durability.
Features:
Abu Garcia
The Gen Ike EZ Cast baitcast combo features a revolutionary Anti-Backlash System
that makes it easy to learn how to use a baitcast reel. The Anti-Backlash System automatically controls the spool which lets you enjoy fishing without fear of line twists or tangles.
Features:
Abu Garcia
The Gen Ike baitcast combo offers cutting edge design and precision performance for first time anglers. The Gen Ike platform features quality components paired with aggressive cosmetics and is available in both spinning and low profile baitcast options. Each 2-piece composite blank is fitted with high density EVA split grips for lightweight comfort and durability.
Features:
Each of these rod/reel combos will be available for purchase August 30, 2020.
The post Abu Garcia Ike Rod & Reel Combos are Perfect for Serious Up-and-Coming Anglers appeared first on OutdoorHub.
Abu Garcia
Features:
- 3 ball bearings + 1 roller bearing
- Pre-spooled with 8lb. Line
- Lightweight graphite body and rotor
- Machined aluminum spool
- Everlast
- Slow oscillation
- Rocket Line Management
- Rocket Spool Lip Design
- 24 Ton graphite
- High density EVA
- Texas rigged hook keeper for all bait applications
Abu Garcia
Features:
- Features Anti-Backlash
- 3 Bearing system
- Pre-spooled with 10lb. Line
- Aluminum handle
- Soft-touch handle knobs
- 6′ Medium action rods
- High density EVA handles
Abu Garcia
Features:
- 4 stainless steel ball bearings + 1 roller bearing
- Pre-spooled with 10lb. line
- Power Disk
- Duragear
- MagTrax
- Compact bent handle
- Recessed reel foot
- One piece graphite frame
- Graphite sideplates
- 24 Ton graphite construction
