$129.95
Select Model
Product Actions
$129.95
Qty.
- 7 stainless steel HPCR™ bearings + 1 roller bearing provides increased corrosion protection
- Carbon Matrix™ hybrid drag system for super smooth reliable drag performance
- IM-C6™ (Insert molded C6) body design combines an X-Cräftic™ gearbox design with a C6 carbon body, which gives a lightweight construction that houses gears in perfect alignment
- Lightweight graphite rotor
- Rocket line management™ system provides better control of all types of fishing lines
- Rocket spool lip design™ allows better control of line coming off the spool
- Large PVC knob provides greater comfort and durability
- Machined aluminum braid ready spool allows braid to be tied directly to the spool without any slip
- Stainless steel main shaft and components for improved corrosion resistance
- Everlast™ bail system for improved durability
- Slow Oscillation provides even line lay with all types of line
Lots of fishers like this reel.
Thinking about adding another Spinning Rod and reel to myself.I think I can go with a white reel..
