HomeBass Cat ModelsCaracal (19’8″)
CARACAL (19’8″)
Bass Cat Caracal
A Wide Throwback
The Caracal name is a throwback to the 17 foot hot rod version that dominated in on water performance at the 1990’s Top 100 Tour. The heritage of the name is preserved in this wide-bodied hull, and it draws a new base to the name. Accolades have adorned it with comments from owners enjoying it. Features include the side insert net scabbard in the port deck, tool and ruler slots, tandem (2) aft storages, port and off-center line rod storage, and even a rod locker for your partner. A day use box is back at the front like those early 1990’s Caracal II models. The massive triangle livewells of the Premium Series lineup populate the rear deck, along with a large starboard storage box. The stability at rest is exceptional for that tippy test. On the run, this model has joined the wide-body concepts that continue to evolve.
MODEL INFO
PHOTOS2021 Bass Cat Caracal
2021 Bass Cat Caracal2021 Bass Cat Caracalhttps://youtu.be/21C5r61IhiE
Request a Price2021 Bass Cat Caracal
Request a Price
Mesa, AZ
Mesa, AZ
VIDEO
BOAT LAYOUT
REQUEST A QUOTE
ANONYMOUS REQUEST
SPECIFICATIONS
Length: 19’8″
Width: 96″
H.P. Rating: 200-225
Fuel Capacity: 43 Gal
Rod Box Length: (Port) 8’0″, (Starboard) 8’0″
Approximate Storage Length:
Engine trimmed down – 25’9″
Engine trimmed down, Tongue Swung – 23’0″
Strength & Performance
Vinyl Ester Resin on 60% – all outer laminate
Engine and OEM Matched Controls (non Verado)
Slidemaster Jackplate
43 Gal of Fuel – 2 Tanks, 33 & 10 Gal (upgradeable to 52 or 59)
Minn Kota Fortrex 80 45″ 24V
Choice of Engine Matched 3 Blade Prop
Pump in and Pump out livewells
100% All Fiberglass Hull Construction
24 Ounce Carpet
3 Rod Boxes – Two Organizer
Pliers holder on front deck
Bow Day Box
Dip Net Scabbard
High Performance 6X BCB Steering Wheel
One (1) AGM Cranking Battery
Tilt Hydraulic Steering
Safety, Security & Electronics
Two (2) Helix 7 CHIRP GPS
Minn Kota 3 Bank Charger
Interactive Digital Switch Panel Livewell Lights
Quicksilver Gauges – Tach, Fuel & Trim
48V Battery Test Gauge
Master Power (2) – At Dash and Crank Battery Breaker
Tinned Wire with NEW 6 Gauge Buss wire strip to Console
Security System & Lighted boxes
Dual (2) 1000 GPH Bilges with Automatic
Lighted Hand Rails
Integrated Stainless Ladder
Battery Tender Trolling Motor Plug
Foam Filled Stringer System
Windscreen (choice – large or small)
Integrated LED Push Button Deck Lighting
Underwater Wake Light
Logo Puddle Light
Caracal resting rear port
Custom & Comfort
One Fold Down & One Butt Seat w/ Pro Pole
Wave Crusher Seats
Bass Cat Logo in Livewell Lids
Recessed Trolling Motor Foot Pedal
Dual Foot-pedal Positions
18″ Measure Rule
Mooring Flip Cleats (2) at Consoles
Marine Town Stainless Steel Latches
Plano Tackle Trays ABS
Dual Rod Straps – Bass Cat
Passenger Rod Bungee
3- R & R Aluminum Battery Trays
Boat Ventilation System
USB Power Outlet
Rubber Non-slip Box Mat
Stainless Cup Holders
Fully Insulated Ice Chest
Removable Rear Deck Lid
Fully Insulated Deck Lids
Bass Cat Trailers
4″ C Channel frame – US Steel – Tandem Five (5) Cross members
Welded to Fit Construction
Fiberglass Fenders
Dual Torqueflex Axles w/ Brakes Dual Axle
Dot 5 Brake Fluid
Fiberglass Step
Pivot Tongue
IMCO Tie Downs
15″ Aluminum Wheel (Rogue)
One PPG Clear Coat
LED Lights
XP Trailer Jack
Bass Cat makes every effort to ensure accuracy of all information. Features, options and information subject to change at any time.
Bass Cat Caracal
A Wide Throwback
MODEL INFO
Request a Price
Mesa, AZ
Mesa, AZ
VIDEO
BOAT LAYOUT
REQUEST A QUOTE
ANONYMOUS REQUEST
SPECIFICATIONS
Length: 19’8″
Width: 96″
24 Ounce Carpet
Bow Day Box
Dip Net Scabbard
Lighted Hand Rails
Logo Puddle Light
Custom & Comfort
Wave Crusher Seats
18″ Measure Rule
USB Power Outlet
Bass Cat Trailers
Fiberglass Fenders
Dot 5 Brake Fluid
Fiberglass Step
Pivot Tongue
IMCO Tie Downs
One PPG Clear Coat
LED Lights
XP Trailer Jack
