Overall, Probably the best built 18ftr on the water..At 18'1" The sabre is 5 to 7 inches shorter than other 18s, but has them beat in fit,finish and performance..to me anyway.. at 1215 lbs, and rated for a 175 it can be set up for a 70 mph ride...awesome..
The Sabre FTD is a perfect example of good things coming in small packages. This model has everything to satisfy even seasoned anglers. Available with up to 175H.P. in an engine brand of your choice, the Sabre FTD provides performance that fits any budget.
This is the model of choice for the angler seeking a lighter, more maneuverable, tournament ready rig. Thanks to an extremely efficient hull design, the Sabre FTD excels at getting the most out of any outboard in terms of fuel economy and performance. It’s ability to draft skinny water makes this 18’1” model the perfect fishing platform for the versatile angler.
The Sabre FTD is not an inexpensive starter. This is a boat with the same construction techniques of the Jaguar. The floor plan helps to maximize the angler’s performance and efficiency through an expansive casting deck and abundant storages.
The Sabre FTD is a sleeper in the Bass Cat line. It captures multiple strengths found across the entire fleet and packages them in a smaller footprint that boasts advantages in many applications.
SPECIFICATIONS
Standard Equipment as priced:
Option of Silhouette colors
2 - Humminbird Helix 7
Minn Kota Fortrex 80 - 45"
Choice of Propeller
Perko Latches w/Locks on Storages
Windscreen
A Ten Touch control panel
Pump in / Pump out 1000GPH Bilge Pump w/Auto
33 Gallons of Fuel in one (1) tank
*May be 5% less with capacity value
Quicksilver Matched Analog Gauge Package
18" Golden Rule
6 x BCB Steering Wheel
R&R Jack Plate / SS-Ladder or E-Ladder
(must specify E-Ladder)
24oz Carpet
One Rod Organizer
One Rod Bungee at Bow
One Rod Bungee Passenger
One Fold Down seat and one Butt Seat w/Pro Pole
12 Volt Outlet in dash
No Lighted Boxes
New Advantage Console w/Courtesy Light Master Power Switch at dash / Crank Battery Breaker
Trim Gauge
Tilt Helm on Hydraulic Steer
Aluminum Battery Straps
Pro Mariner - 3 Bank Battery Charger
Foam Filled Stringer System
Trailer Features
Single Axle
Color Matched
4" C Channel frame - US Steel
Pivot Tongue
IMCO Tie Downs
Disc Brakes
15" Rogue Wheels & Black Wall Tires
Fiberglass Trailer Step
Vault Hubs
PPG Clear Coat (1)
SPECIFICATIONS
- Length - 18'1"
- Min Storage Length - 24'
- W/Swing Away Tongue - 21'
- Beam - 93"
- Approx Boat Weight - 1215lbs
- Fuel Capacity - 33 gallons
- Max H.P. Range - 115-175
Choice of Propeller
Windscreen
18" Golden Rule
24oz Carpet
One Rod Organizer
No Lighted Boxes
Trim Gauge
Trailer Features
Single Axle
Color Matched
Pivot Tongue
IMCO Tie Downs
Disc Brakes
Vault Hubs
PPG Clear Coat (1)
