What about these
are they some dealers?
any on the lakes
dont see much
cool boat...livewell system ..neat
PO Box 709
Richland, MO 65556
CHARGER 496 l SPECIFICATIONSOverall Length:20'6"Beam:95"Weight:1650 lbsMax H.P.Any V-6Molded Depth:41"Max Person/Capacity:6/900 lbsMax Weight Capacity:1500 lbs.Gas Tank:44 gal.Storage Compartments:12BOAT LENGTH ON TRAILERFull Length:25'3"Swing Away Tongue:22'9"496 Available in dual console only.
CHARGER 496 FEATURES:Bow panel with trim switch and courtesy light switch, Built-in pork chunk/ lure tray, Exclusive Lean/ Butt Seat, L.E.D. courtesy lights, Rod strap, Dual oversized rod lockers, Tackle tray system, Lockable storage compartments w/power assist aluminum lids, Rod rack, Passenger side glove box (dual console only), Footrest under consoles, 20-ounce carpeting, Console courtesy lights, Console w/full instrumentation, built-in space for electronics, Lowrance X-52 depth finder w/surface temp. Passenger side rod ramp w/bungee rod strap, Wrap-around couch lumbar support seating, Ice chest, Chrome deck vents, Dual independent aerated livewells, recirculating Charge-air system w/pumpout, livewell lights, remote drains, Dual Pro battery charger, Easy access split engine compartments, Built-in jack plate, 4" thick transom.
596 l 496 l 396 l F&S 375/475 l 296 l Pro Team 296 l SUV 210/190 l 186 l 176 l Bay Boat l
Charger Boats PO Box 709 Richland, MO 65556 Phone: 573-765-3265 © 2009 Charger Boats
any on the lakes
dont see much
CHARGER ADVANTAGE
FEATURES
CHARGER BOATSFEATURES
PO Box 709
Richland, MO 65556
573-765-3265
:: 496 LIFETIME WARRANTY-100% COMPOSITE
If you've ever taken a close look at a Charger 496, you'll see why it's our most popular tournament boat. Because the 496 was designed by serious fishermen, for serious fishermen. Want power & speed? No problem. Like its bigger brother, the 496 is rated for any V-6 outboard. Need space & storage? The 95-inch beam and 10 storage compartments give you room to spare. Want convenience? Standard features like new L.E.D. courtesy lights, stainless steel fold-down cleats and our exclusive built-in pork chunk tray let you concentrate on catching fish.
When the competition gets tough, go with a proven winner: The Charger 496
CD-34 Tube Construction Tandem Axle Trailer w/Deluxe Package
Custom Paint & Pinstriping, Center Mount Jack, Disc Brakes on One Axle, Double Carpeted Bunks, Fender Well Covers, Aluminum Diamond Plate Step Pads, Lighted Charger Cut Out, Recessed Tail Lights, Outlined White Letter Radials on Aluminum Mag Wheels, Spare Tire Carrier w/Spare tire, Retractable Tie Downs, XLT Winch, Backup Lights, Oil Bath Hubs, L.E.D. Lighting
