DAIWA’s NEW Multispecies 24 KAGE LT Spinning Reel
The new DAIWA 24 KAGE LT Spinning is now available for purchase through DAIWA dealers, this is a new multispecies spinning reel that fully embraces the LT (Light/Tough) reel concept. The 24 KAGE LT sports a ton of features that make it just that: a light and tough reel, starting with the ZAION reel body. Made from woven high-density carbon ZAION resin, the body of the reel is very light, rigid, and durable. Next to keep the reel light is the AIR Rotor, a rigid lightweight rotor design that has been engineered to have minimal flex even under high drag pressures when fighting big fish. On top of the AIR Rotor is the AIR Bail, a lightweight bail system that uses hollow stainless steel tubing that is lighter and more rigid than traditional solid bail wires. On the inside of the reel is the TOUGH Digigear, an oversized gear that is made of hard and lightweight 7075 aircraft-grade aluminum. These gears are precision machined and digitally cut for the best gear meshing possible for a smoother reeling experience.
The new DAIWA 24 KAGE LT is available in five sizes, 1000, 2000, 2500, 3000, and 4000, and has an MSRP of $249.99 to $269.99 depending on the model. These are available now at any Brick and Mortar Daiwa Dealer near you.
DAIWA Field Marketing Manager, Chris Martin, said, “We developed the KAGE LT to be incredibly lightweight for its size. This, while maintaining rigidity, bolstering sensitivity, and adding a level of corrosion resistance.”
Martin continued, “The KAGE LT is the perfect utility spinning reel for multispecies anglers. Whether you’re chasing bass, walleyes, trout, or panfish, this reel will do it all. And with options down to a 1000-size, it’s tailormade for finesse fishing.”
24 KAGE LT – 1000, 2000, and 2500 size reels come with a premium cork handle
Daiwa 24 KAGE LT Spinning Reel Key Features
The post DAIWA’s NEW Multispecies 24 KAGE LT Spinning Reel appeared first on OutdoorHub.
- 6 + 1 Ball Bearings
- ZAION Body – Lighter than aluminum and Magnesium but still extremely strong body made of woven high-density carbon resin ZAION material.
- AIR Rotor – Smart design to lessen the weight of the rotor, providing even rotary balance and stress distribution.
- AIR Bail – A hollow tubular stainless steel bail that delivers maximum rigidity and strength, while weighing as little as possible.
- Tough Digigear – 7075 Aircraft Grade aluminum forged oversized large tooth patterned gear that meshes perfectly for an ultra-tough drive system that is still smooth.
- 2BB Supported ATD (Advanced Tournament Drag) – Two ball bearings support the lightweight spool, resulting in a smooth frictionless payout as the spool engages and rotates.
- Machined Aluminum Screw in Handle – Precision machined reel handle that gives a smooth and secure fit.
- Gear Ratio – 6.2
- Weight – 6 oz, 6.2 oz, 6.3 oz, 7.4 oz, 7.8 oz
- Max Drag – 11lb, 11lb, 11lb, 22lb, 26.4lb
- Reel Sizes – 1000, 2000, 2500, 3000, 4000
- MSRP – $249.99 – $269.99
