- Jan 16, 2009
- SouthEast Arkansas
One of the most interesting boats I have seen is Eagles G3 boat...especially the 190. To me it has a very interesting layout and can handle enough hp to be a tough competitor on the water.
Here is a list of the spec's on the boat
Length: 18' 8"
*Package Length: 23' 10"
Beam: 85"
Package Width: 85"
Bottom Width: 58"
Transom Height: 20"
Side Depth: 25"
Hull Gauge: .100
Max HP: 150
Fuel Capacity: 21G.
Livewell Dimensions
& Capacities: 14"x41" 27G.
Color Options: Black / Platinum
Ivory Silver
And here is the Yamaha motor options available from the factory
F90TLR
90TLR
F115TLR
115TLR
F150TLR
VZ150TLR
V150TLR
Here is the basic construction of the boat
Construction & Components
•Marine grade, pressure treated plywood floors & decks with limited lifetime warranty add to the overall value of the mod-v line.
•NEW GENERATION Performance stepped hull w/ 58" bottom for added stability and improved turning capabilities.
•Wide-body 85" beam provides more deck space and excellent stability while casting.
•Extruded longitudinal stringer system running the full length of the hull for added strength and performance.
•18 ounce marine grade carpet is durable and fade resistant.
•Two tone Ivory/Silver or Black / platinum finish color combo adds to curb appeal and resale.
•21 gallon built in fuel tank increase distance between fill-ups and extends your fishing range.
•Baked on two part high gloss urethane metallic hull finish for a great looking finish that endures.
•Two piece .100 gauge welded hull for superior strength and rigidity.
•Fuel Separator helps to eliminate excess water from gas and gives peace of mind and consistent performance.
•All aluminum lids are lightweight, durable and strong.
•Transom saver secures your engine for travel, reduces stress on transom during transportation.
•Custom powder-coated 3" tubular steel TRAIL GUARD® trailer w/ LOCKING DETACHABLE TONGUE. Space saving & security! 4 custom bunks provide easy loading and a higher degree of hull protection.
•G3 ADVANTAGE WARRANTY adds value with an extended warranty on all external seams for the "duration of ownership" for the original retail purchaser. Limited five year bow to stern non pro-rated structural warranty transferable once within 5 years of purchase
Personally I feel like this boat would serve well fo a weekend angler and possible tourney.
Length: 18' 8"
Beam: 85"
Package Width: 85"
Bottom Width: 58"
Transom Height: 20"
Side Depth: 25"
Hull Gauge: .100
Max HP: 150
Fuel Capacity: 21G.
Livewell Dimensions
Ivory Silver
F90TLR
90TLR
F115TLR
115TLR
F150TLR
VZ150TLR
V150TLR
