Fenwick Eagle Inshore Spinning Rods – The Next Step in Precision and Performance
Fenwick is keeping the legacy of innovation going with the new Eagle Inshore Spinning Rods, the newest addition to the Eagle Series of rods from Fenwick. These spinning rods have been designed from the ground up to deliver uncompromising sensitivity, crisp action, and all-day comfort. The blanks of the new Eagle Inshore Spinning Rods are made of a proprietary blend of 24- and 30-ton graphite and a proprietary reinforcing resin. Giving the rods the classic Fenwick feel with modern upgrades that improve the performance for inshore techniques. The new Fenwick Eagle Inshore rods come with tailored foregrips and added taper for finger placement. These grips are full-length and multi-material and have been balanced for durability and sensitivity. The guides are made of stainless steel with thin zirconia inserts for better castability and corrosion resistance. Lastly, the reel seats are a Fenwick soft-touch design that gives direct access to the blank for better bite detection.
“The Eagle Inshore delivers the same traditional Fenwick craftsmanship anglers have always trusted, but now with a refined design that fits the way today’s anglers fish,” said Tyler Schmidt, Brand Manager at Fenwick. “We built this series to balance comfort, sensitivity, and durability while introducing technique-specific actions that take the Eagle legacy to the next level.”
Fenwick Eagle Inshore Spinning Rods Key Features
  • 24/30 ton graphite blend blank with proprietary reinforcing resin
  • Tailored foregrip with reduced length and added taper
  • Interlocking part lines for smooth transition and best hand feel
  • Contoured rod butt with increased radii
  • Stainless steel guide frames with thin zirconia inserts
  • Fenwick designed reel seat
  • Limited lifetime warranty
  • Rod Type – Spinning Rod
  • Grip – Multi-material full-length grips
  • Power – Medium Light, Medium, Medium Heavy
  • Action – Fast
  • Length – 7′, 7’6″
  • Pieces – 1
  • Line Weight – 6 – 12 lb, 8 – 17 lb, 12 – 25 lb
  • Lure Weight – 1/16 – 5/8 oz, 1/8 – 1 oz, 1/2 – 1 1/2 oz
  • MSRP – $139.95-$149.95
  • Availability – October 2025
The post Fenwick Eagle Inshore Spinning Rods – The Next Step in Precision and Performance appeared first on OutdoorHub.
