Fish Without Backlashes with the Abu Garcia Max X EZ Cast Combo
Abu Garcia is here to make life a little easier on the water when baitcasting with the new Max X EZ Cast Baitcast Combo. This is a new baitcaster combo designed specifically to help lower the learning curve of using a baitcast reel. All ot this in a compact combo package with a 6ft 1pc or 2pc rod, depending on the model. At the core of the Max X EZ Cast Combo is Abu Garcia’s new anti-backlash system. It automatically controls the spool to eliminate backlashes during casts. It comes with an integrated on and off switch so anglers can choose when to have it on, so that once they master their casting technique, they can fish without it. That way, the new Max X EZ Cast combo offers the perfect blend of learning support and performance versatility. The reel of the combo comes with a graphite frame and sideplates and comes with 3+1 bearings. The reel has a max drag of 15lbs and ships prespooled with 10lb monofilament line. This new combo will be available in August 2025 and has an MSRP of $59.99
Abu Garcia Max X EZ Cast Combo Key Features
The post Fish Without Backlashes with the Abu Garcia Max X EZ Cast Combo appeared first on OutdoorHub.
- Bass Pro Shops BIO Bait Review: Does It Actually Do What It Claims?
- Bomber Time At Island Lake
- Kayak Fishing Gear Don’t-Buys: Don’t Waste Your Money
- An innovative and easy-to-use anti-backlash system that automatically controls the speed of the spool, eliminating line twists and tangles for a smoother, beginner-friendly baitcasting experience
- 3 Bearing + 1 roller bearing provides smooth operation
- Graphite frame and sideplates
- Pre-spooled with 10 lb. Line
- 6’ Medium action lightweight carbon composite rod in 1 pc. or 2 pc.
- Lightweight graphite composite blank with EVA split grip handle design
- Bearings – 3+1
- Gear Ratio – 6.1:1
- Braid Capacity – 135/20 110/30 75/50
- Max Drag – 15 lb
- Line Rating – 6 – 12 lb
- Rod Type – Casting
- Rod Grip – EVA Split Grip
- Power – Medium
- Action – Moderate Fast
- Rod Length – 6 ft
- Rod Pieces – 1 piece or 2 pieces
- MSRP – $59.99
- Availability – August 2025
