Go Wild with Shakespeare – Shakespeare Wild Series Rods and Combos
Shakespeare has another series to its lineup to get anglers outside with the new Shakespeare Wild Series. A purpose-built collection of rods and combos designed to perform reliably for a wide range of freshwater species. The Wild Series of rods and combos are all built for versatility using advanced materials and dependable construction while still tailored for angler value, so the rods and combos won’t kill your wallet before the holidays. Each Wild series rod uses a 70% carbon composite blank and premium cork grips. For the combos, the matching reels are made with lightweight yet durable aluminum components and soft-touch comfort features to help with long days on the water. And for anglers with limited space while traveling, there is even a specialized travel-ready option as well.
Go Wild with Shakespeare – Shakespeare Wild Series Spinning Rods and Combos
Shakespeare Wild Series Spinning Rods and Combos Key Features
  • Carbon composite rod blank construction
  • Stainless steel guides with stainless steel inserts
  • Premium cork handles
  • Molded reel foot and handle knob soft touch grips
  • Aluminum spool and handle arm
  • Thick aluminum bail wire
  • Bearings – 4 ball bearings + 1 roller bearing
  • MSRP – Rods: $36.99-$41.99 • Combos: $84.99-$94.99
  • Availability – October 2025
Go Wild with Shakespeare – Shakespeare Wild Series Travel Rods and Combos
Shakespeare Wild Series Travel Rods and Combos Key Features
  • 3-piece rod construction
  • Peggable tube packaging (rods)
  • Includes travel bag for easy transport and storage (combos)
  • Thick aluminum bail wire for increased strength
  • MSRP – Rod: $41.99 • Combo: $94.99
Go Wild with Shakespeare – Shakespeare Wild Series Conventional Rods and Combos
Shakespeare Wild Series Conventional Rods and Combos Key Features
  • 20-size conventional reel
  • Stainless steel synchronized level wind
  • On/off selective bait clicker
  • Bearings – 2 ball bearings
  • MSRP – Rods: $36.99-$41.99 • Combos: $94.99
The post Go Wild with Shakespeare – Shakespeare Wild Series Rods and Combos appeared first on OutdoorHub.
