[ICAST 2023] Grundens’ NEW Boundary Zip Stockingfoot Wader
Grundens has unveiled its latest pair of waders at ICAST 2023. Industry leaders in everything to keep you dry in the water since 1911, Grundens is no stranger to the waders market. The new Boundary Zip Stockingfoot waders are built and designed around the GORE-TEX Pro Wader laminate material to give anglers the best possible range of motion in and out of the water. Grundens reworked the way waders were assembled by adjusting the cut of the materials and removing seams from the usual areas of heavy wear. The newly designed wader suspenders take inspiration from climbing harnesses to make them one of the most comfortable harnesses on the market. This wader innovation even extends to the wader feet, of anatomically shaped neoprene sock. They use dual-density neoprene with two layers of titanium coating that retains body heat and keeps your feet comfy in cold trout streams. These waders are available for purchase now and retail for $899.99.
Grundens Boundary Zip Stockingfoot Waders Key Features
Special thanks to Grunden’s staff here at ICAST 2023, and stick around for more ICAST coverage. Also, let us know your thoughts in the comments below, we appreciate your feedback.
The post [ICAST 2023] Grundens’ NEW Boundary Zip Stockingfoot Wader appeared first on OutdoorHub.
- Body mapped GORE-TEX Pro Wader laminate- 4 layers in the lower body for abrasion resistance and 3 layers in the upper body for breathability.
- YKK Aquaseal waterproof and submersible center front zipper
- Neoprene booties use two layers of Titanium-Alpha to increase heat retention back to the body up to 40%
- Inspired by premium climbing harnesses, the fused contour suspension system moves with you through casting and rowing motions. Integrated D-Ring net holder and fully customizable fit for all day comfort.
- Double weave stretch woven gravel guards stay secure to the boot while wading, removing the need for a boot hook.
- Anatomically placed seams reduce wear in critical areas.
- Two fleece lined chest hand warmer pockets.
- Two drop in vertical access chest storage pockets designed for two fly boxes and oversized tippet spools.
- 2 inch elastic wading belt included.
- MSRP – $899.99
- Available Now
