[ICAST 2025] A Space Age Spinning Reel – Trika Ti Series Spinning Reel
Trika, maker of high-quality fishing gear, is here at ICAST 2025 showing off one of their new space-age material fishing reels. The Trika Ti Series Spinning Reel is a new sealed spinning reel that is loaded up with advanced features. Inside the sealed body is a Diamond-Like Carbon (DLC)- coated titanium main shaft that resists corrosion and is incredibly rigid, giving no flex even under pressure. The drag for the reels uses titanium drag plates for better heat-resistance and smooth function when under load, letting these reels have a max drag anywhere from 10 to 20 pounds, depending on the model. The gearing for the reels has been micro-toleranced for smooth reeling and power transfer. The Trika Ti Series spinning reels all come with 8+1 ABEC 5 sealed bearings for better water and salt resistance and come with a one-piece titanium bail. This all combines into a spinning reel that gives incredibly smooth performance for the long run. The Trika Ti Spinning reels are available now in five sizes, 1000 – 4000, and the MSRP for the reels starts at $249 for the 1000 and goes up to $299 for the 4000 size reel.
ICAST Coverage on OutdoorHub
Trika Ti Series Spinning Reel Key Features
  • DLC-coated titanium shaft – Lightweight, ultra-durable, low friction
  • Titanium & AvCarb drag washers – Smooth, consistent, heat-resistant
  • Titanium one-piece bail wire – Stronger, lighter, fully corrosion-proof
  • 8+1 sealed stainless bearings – Corrosion-resistant, smooth retrieve
  • Aluminum frame & CNC spool – Rigid, lightweight, balanced performance
  • Fully sealed body – Blocks water, sand, and debris
  • Type II hard anodized finish – Corrosion resistance, long-lasting durability
  • Bearings – 8+1 ABEC 5 Sealed Bearings
  • Gear Ratio – 5.2:1 (1000 – 2500 reels), 6:1 (3000, 4000 reels)
  • Line Retrieve Per Crank – 25.8″ (1000 – 2500), 32.7″ (3000), 35.7″ (4000)
  • Weight – 6.2 oz (1000), 6.3 oz (2000, 2500), 7.2 oz (3000), 7.5 oz (4000)
  • Mono Line Capacity – 6lb/100yds (1000), 8lb/100yds (2000), 8lb/125yds (2500), 10lb/125yds (3000), 12lb/125yds (4000)
  • Braid Line Capacity – 10lb/110yds (1000), 10lb/125yds (2000), 10lb/150yds (2500), 20lb/130yds (3000), 30lb/140yds (4000)
  • Max Drag – 10lb (1000), 13lb (2000, 2500), 15lb (3000), 20lb (4000)
  • MSRP – $249 – $299
  • Availability – Now
Special thanks to the Trika staff here at ICAST 2025, and stick around for more ICAST coverage of all things new in fishing on OutdoorHub.
The post [ICAST 2025] A Space Age Spinning Reel – Trika Ti Series Spinning Reel appeared first on OutdoorHub.
