[ICAST 2025] Best New Fishing Line of ICAST – PowerPro Max-8
PowerPro has won Best of Category for Fishing Line in the ICAST 2025 New Product Showcase with the new PowerPro Max-8 braided fishing line. This is a new high-performance braided fishing line designed for offshore anglers looking for a rugged and smooth casting braided line that offers superior control while offshore. Built with an 8-carrier Spectra HT fiber construction, the new Max-8 cuts through the water, reducing drag and scope in the line when used for vertical jigging, trolling, and casting applications. This new construction makes it 25% thinner than comparable lines, giving anglers increased line capacity without sacrificing line strength. Made with Enhanced Body Technology (EBT) engineering, each fiber is infused with resin, making a smoother, rounder, and more durable line. PowerPro Max-8 is available in the line test ratings of: 30lb, 40lb, 50lb, 65lb, 80lb, and 100lb. It has two color options, 4-color and white, and comes in spool lengths of 333yds, 500yds, 1500yds, and 3000yds for all line tests. MSRP ranges from $84.99 – $999.99 (White) and $99.99 – $1119.99 (4-Color), depending on line test and length.
ICAST Coverage on OutdoorHub
PowerPro Max-8 Braided Fishing Line Key Features
Special thanks to the PowerPro staff here at ICAST 2025, and stick around for more ICAST coverage of all things new in fishing on OutdoorHub.
The post [ICAST 2025] Best New Fishing Line of ICAST – PowerPro Max-8 appeared first on OutdoorHub.
- [ICAST 2025] The New Lightweight Hobie iTrek Angler Fishing Kayak
- [ICAST 2025] Bates Fishing Co. New Digital Casting Control Reel – EDC 100
- [ICAST 2025] Shimano’s Ultimate Swimbait Tackle System
- Available Line Test – 30lb, 40lb, 50lb, 65lb, 80lb, 100lb
- Line Diameter Inches – 0.009, 0.011, 0.012, 0.014, 0.016, 0.017
- Line Diameter Millimeters – 0.23, 0.28, 0.30, 0.36, 0.41, 0.43
- Comparable Mono Diameter – 6lb, 8lb, 10lb, 12lb, 16lb, 18lb
- Available Lengths – 333yds, 500yds, 1500yds, 3000yds
- Available Colors – White, 4-Color
- MSRP – $84.99 – $999.99 (White) and $99.99 – $1119.99 (4-Color)
- Availability – Available Now
