[ICAST 2025] Cutting Edge Cutters with the SORD Mono Nippers
Makers of quality fillet knives and fishing tools, SORD Fishing Products is here at ICAST 2025 with a new rigging tool, the SORD Mono Nippers. These are a new set of monofilament line cutters that have been meticulously tested on the water by SORD. While many would wonder what could be so fancy about some line cutters, SORD has put in the effort to make these as easy, efficient, and durable as possible. From microserrations on the blade edge for a superior cut quality to the transparent titanium coating for corrosion protection, every feature has been carefully considered for the SORD Mono Nippers, such as material choice, with every metal component being a stainless steel and the handles being a UV-resistant ASA polymer. Even the locking mechanism was engineered to be easily manipulated and with just your thumb, so you can easily rig or cut line as needed on the water. Additionally, when combined with the SORD leather sheath and rigging knife, it makes for a compact package on your hip that keeps all your tools right on you. The SORD Mono Nippers have an MSRP of $49.99 and will be available later this year.
ICAST Coverage on OutdoorHub
SORD Mono Nippers Key Features
Special thanks to the SORD Fishing Products staff here at ICAST 2025, and stick around for more ICAST coverage of all things new in fishing on OutdoorHub.
The post [ICAST 2025] Cutting Edge Cutters with the SORD Mono Nippers appeared first on OutdoorHub.
- [ICAST 2025] Daiwa’s D-SHOCK II Combo – Able and Affordable
- [ICAST 2025] Hobie Eyewear Hull Float – Upcycled Hobie Kayak Plastics
- [ICAST 2025] A Space Age Spinning Reel – Trika Ti Series Spinning Reel
- Optimized for cleanly cutting monofilament line
- Micro-Serrations on the jaws help cleanly cut both monofilament and braided line
- Ergonomic grip for comfort and control
- Corrosion-resistant stainless components
- Transparent Titanium Coating for added corrosion resistance
- Spring-loaded for ease of use
- Locking mechanism for safe storage
- Length – 18 cm
- Width – 4.8 cm
- Thickness – 1.75 cm
- Jaw & Body Material – Japanese 420 Stainless Steel
- Handle Material – ASA Polymer – UV-Resistant and Highly Durable
- Spring, Lock, & Rivet Material – 316 Stainless Steel
- Jaw Hardness –50 – 52 HRC
- MSRP – $49.99
- Availability – September 2025
