[ICAST 2025] Daiwa’s D-SHOCK II Combo – Able and Affordable
Daiwa is here at ICAST 2025 bringing in a very able and affordable spinning combo with the new D-Shock II Combo. This is a new line of budget-oriented spinning combos that are still very capable on the water. Made up of five different models of 2-piece spinning combos that range from 5’6″ to 7′, the new D-Shock II combos are a great choice for people just getting into fishing, no matter where they are in the country. The rods are all made with very forgiving fiberglass blanks with quality cork handles and titanium oxide guides. The reels all come prespooled up with Daiwa’s J-Braid X4 fishing line, so just tie on your rig and you are good to go. The new Daiwa D-Shock II Combos have an MSRP of $39.99 and will be available later this year
ICAST Coverage on OutdoorHub
Daiwa D-SHOCK II Combo Key Features
  • Strong Fiberglass Blanks – Ultra-strong fiberglass for an incredibly strong and durable blank.
  • Cork Grips – Lightweight and durable cork grip that provides comfort and optimum control.
  • 2-Piece Blank – Lightweight and sensitive, easy for transportation.
  • Preloaded with J-Braid X4 – Reels come prespooled with J-Braid for easy use.
  • Titanium Oxide Guides
  • Bearings – 4+1 (10, 20), 5+1 (25, 30, 40)
  • Rod Line Rating – 2-6lb(10), 4-10lb(20), 6-14lb(25, 30), 10-20lb(40)
  • Rod Type – Spinning
  • Rod Grip – Full-Grips Cork Handles
  • Rod Length – 5’6″, 6’0″, 6’6″, 7’0″
  • Rod Pieces – 2 Pieces
  • MSRP – $39.99
  • Availability – Late 2025
Special thanks to the Daiwa staff here at ICAST 2025, and stick around for more ICAST coverage of all things new in fishing on OutdoorHub.
The post [ICAST 2025] Daiwa’s D-SHOCK II Combo – Able and Affordable appeared first on OutdoorHub.
