[ICAST 2025] SEVIIN’s New Aluminum Dream – Elite-Level GX Series Baitcast Reels
SEVIIN is here at the biggest fishing show of the year, ICAST 2025, with their new aluminum dream reel, the new GX Series Baitcast Reels. This is a series of six all-new 150-size GX baitcasters, joining SEVIIN’s GX Series spinning reels from last year. All of these new baitcasters come with a lightweight and rigid aluminum frame and gear-side cover. Inside that frame are 9+1 stainless steel bearings, an aluminum drive gear, and a brass pinion gear. The drag is comprised of carbon fiber and stainless-steel washers for smooth drag that delivers 13 to 21 pounds of max drag force, depending on the model of reel. Three gear ratios – 6.6:1, 7.3:1, and 8.1:1 – are available in both left and right-handed options, with all six GX Series Baitcast reels having an MSRP of $220. The new GX Series Baitcast reels all come backed by a One-year no-questions-asked warranty and should be available this December.
ICAST Coverage on OutdoorHub
SEVIIN GX Series Baitcast Reels Key Features
Special thanks to the SEVIIN staff here at ICAST 2025, and stick around for more ICAST coverage of all things new in fishing on OutdoorHub.
The post [ICAST 2025] SEVIIN’s New Aluminum Dream – Elite-Level GX Series Baitcast Reels appeared first on OutdoorHub.
- [ICAST 2024] St. Croix GXR Bass System – Best of Category
- [ICAST 2024] Berkley Fusion19 Hybrid Jighead
- [ICAST 2024] Sord Fishing Products – 8″ Super Flex Fillet Knife
- Lightweight & rigid one-piece 150-size aluminum frame with aluminum gear-side cover
- Composite palm-side cover and front facia
- Custom-designed 95-mm carbon fiber handle with integrated hook keepers and soft-touch paddle grips
- Variable-depth 34-mm lightweight and ported forged-aluminum spools, optimized by model
- Strong multi-stack carbon fiber/stainless-steel drag system
- Highly adjustable, dual magnetic/centrifugal braking system
- Aluminum drive gear and brass pinion gear for maximum longevity with exceptional feel
- One-year warranty backed by a no-questions-asked accelerated replacement program
- Designed in Park Falls, Wisconsin, U.S.A.
- Left- or Right-handed models are available for each reel model.
- Bearings – 9 + 1 Stainless Steel BB
- Gear Ratio – 6.6:1 (GXC166), 7.3:1 (GXC173), 8.1:1 (GXC181)
- Line Retrieve Per Crank – 28″ (GXC166), 31″ (GXC173), 34″ (GXC181)
- Weight – 7.2oz
- Mono Line Capacity – 150yd/12lb (GXC166), 135yd/12lb (GXC173), 105yd/12lb (GXC181)
- Braid Line Capacity – 110yd/40lb (GXC166), 105yd/40lb (GXC173), 95yd/40lb (GXC181)
- Max Drag – 21lb (GXC166), 18lb (GXC173), 13lb (GXC181)
- MSRP – $220
- Availability – December 2025
