[ICAST 2025] The NEW Award Winning Quantum Merit Spinning Reel
Quantum Fishing is here at ICAST 2025 showing off a new spinning reel, the Quantum Merit. This is a new spinning reel that plans to redefine affordable fishing tackle, offering premium features that anglers typically see with higher-priced spinning reels. Part of the 2025 Best Rod & Reel Combo of the ICAST 2025 New Product Showcase, the Quantum Merit comes with the Quantum Sealoq 6 technology. This is equivalent to IPX6 sealing standards for reel, keeping the internals safe from water, salt, and sand intrusion. The drag of the reel is a CFX200 Carbon Fiber drag system that produces a smooth and consistent drag curve that is capable of capping out at 15lbs to 35lbs, depending on the reel size. The reel body and rotor are constructed with a high-strength graphite, with aluminum sideplates on the rotor for reinforcement. The Quantum Merit aims to strike an ideal balance between durability and lightweight performance. The Quantum Merit spinning reel will be available in sizes 2500 to 8000 and has an MSRP of $99.95 to $149.95, depending on the model. These spinning reels will be on shelves this Fall.
ICAST Coverage on OutdoorHub
[ICAST 2025] The NEW Award-Winning Quantum Merit Spinning Reel
Quantum Merit Spinning Reel Key Features
Special thanks to the Quantum Fishing staff here at ICAST 2025, and stick around for more ICAST coverage of all things new in fishing on OutdoorHub.
The post [ICAST 2025] The NEW Award Winning Quantum Merit Spinning Reel appeared first on OutdoorHub.
- [ICAST 2025] Turtlebox Grande – A Bigger and Tougher Outdoor Speaker
- [ICAST 2025] Turtlebox Ranger – Best in Category Non-Motorized Boating Accessory
- [ICAST 2025] Humminbird XPLORE – Best in Category Marine Electronics
- SEALED TO IPX6 STANDARDS – Sealoq
6 – keeps water, salt, and sand from entering the gear
box and drag system. - CFX200
– CARBON FIBER EXTREME DRAG SYSTEM, for best-in-class max drags and a superior
drag curve. - HIGH STRENGTH GRAPHITE BODY AND ROTOR, with an aluminum sideplate, provides an ideal
ratio of strength to weight. - 4 SEALED STAINLESS STEEL BEARINGS deliver a smooth retrieve.
- DUR-LOQ
CLUTCH delivers instant hook sets, with no back play in the rotor.
- Bearings – 4 + 1
- Gear Ratio – 6.2:1(2500, 3000, 4000), 5.6:1(5000,6000), 4.7:1(8000)
- Line Retrieve Per Crank – 33″ ( 2500), 35″ (3000), 37″ (4000), 38″ (5000), 41″ (6000), 38″ (8000)
- Weight – 10.6oz(2500), 11.7oz(3000), 13.1oz(4000), 17.1oz(5000), 19.8oz(6000), 26oz(8000)
- Mono Line Capacity – 210/8 ( 2500), 215/10 (3000), 220/12 (4000), 255/15 (5000), 315/20 (6000), 390/25 (8000)
- Braid Line Capacity – 275/10 ( 2500), 275/15 (3000), 300/20 (4000), 400/30 (5000), 375/50 (6000), 410/65 (8000)
- Max Drag – 15lb to 35lb
- MSRP – $99.95 – $149.95, depending on model
- Availability – Fall 2025
