[ICAST 2025] The New Lightweight Hobie iTrek Angler Fishing Kayak
Hobie Kayak is here at ICAST 2025 with a new lightweight inflatable fishing kayak option with the new iTrek Angler fishing kayak. This new inflatable option from Hobie Kayak is a lightweight option for kayak anglers on the go, coming in at only 26 pounds unrigged, and about 35 to 38 pounds fully rigged and ready to fish. The new iTrek Angler comes equipped with H-Rails mounted to the deck from the factory, letting anglers easily attach the provided rod organizer, rod holder, and any other accessories you want on your fishing kayak. In addition to the rod organizer and rod holder, the new iTrek Angler ships with a paddle, webbed set, and a Hobie MirageDrive 180 that comes equipped with Turbo Kickup Fins. And if peddling isn’t how you like to roll, the three gudgeons and Motor mount on the back of the iTrek Angler lets you easily mount a motor, steering, and electronics to the kayak. This welded-seam construction inflatable kayak is available in a 10ft or 12ft with an MSRP of $2399 to $2699, depending on size. These should be available for kayak anglers starting this September.
ICAST Coverage on OutdoorHub
Hobie Kayak iTrek Angler Inflatable Fishing Kayak Key Features
Special thanks to the Hobie Kayak staff here at ICAST 2025, and stick around for more ICAST coverage of all things new in fishing on OutdoorHub.
The post [ICAST 2025] The New Lightweight Hobie iTrek Angler Fishing Kayak appeared first on OutdoorHub.
- [ICAST 2025] Bates Fishing Co. New Digital Casting Control Reel – EDC 100
- [ICAST 2025] Shimano’s Ultimate Swimbait Tackle System
- [ICAST 2025] Shimano’s Newest Serious Bass Reel – The Curado 150 M
- H-Rail Equipped – Installed from the factory for mounting accessories
- Ships with Rod Organizer, Rod Holder, Paddle, Seat, and Steering System.
- Comes with the Hobie MirageDrive 180 with Turbo Kickup Fins
- Comes equipped with a Battery mount and strap
- Motor Mount Equipped for adding on electronic propulsion
- Bimini Shade or Sail Mount preinstalled on the front
- Three Gudgeon System – 3 quick-connect spots on the back of the kayak for a rudder, transducer, etc.
- Welded Seam Construction
- Width – 44”
- Fill Pressure – 10 psi (center), 3 psi (outer pontoons)
- Weight Unloaded – 26 lbs
- Weight Fitted – 35 – 38 lbs
- Max Run Time – 960 Minutes
- MSRP – $2399 (10ft) and $2699 (12ft)
- Availability – September 2025
