[ICAST 2025] The NEW Okuma Tesoro Lever Drag Jigging Reel
Okuma Fishing Tackle is at ICAST 2025, proudly announcing the launch of an Asian-Jigging market-inspired reel, the new Tesoro Lever Drag Jigging reel. Made to meet the demands of saltwater jigging, where the majority of the fight relies on the strength of the reel, the Lesoro Lever Drag has been designed from the ground up to meet the power and performance needs of jigging anglers. The core of the reel is the rigid 6061-T6 aluminum frame, machined from a single solid block. The sides plates of the reel are both forged and then machined from aluminum to ensure alignment and strength, even under the 46 lbs of drag force that the reel can exert. Talking of the drag, the Tesoro Lever Drag comes with a Carbonite Dual Force Drag system that has drag washers on both sides of the spool to apply even and smooth pressure. Getting into the internals of the reel, the reel features XL gearing built with an oversized 303-grade stainless steel drive and pinion gears. Alongside the gearing, there are 9 corrosion-resistant stainless bearings and 2 thrust bearings for a long-lasting, smooth feel to the reel. As well as a triple Anti-reverse system that uses dual one-way bearings backed by a mechanical ratchet, eliminating handle back play. And finally, the reel features a spool lock that lets anglers easily break off when they are snagged on the bottom, so no need to grab the spool to keep the drag from slipping while you struggle with trying to pop off your snagged jigs. The feature-packed Tesoro Lever Drag Jigging Reel is available in both left and right-handed models with an MSRP of $449.99. These reels come backed by a 3-year limited warranty from Okuma and are available now.
ICAST Coverage on OutdoorHub
Okuma Tesoro Lever Drag Jigging Reel Key Features
Special thanks to the Okuma staff here at ICAST 2025, and stick around for more ICAST coverage of all things new in fishing on OutdoorHub.
The post [ICAST 2025] The NEW Okuma Tesoro Lever Drag Jigging Reel appeared first on OutdoorHub.
- [ICAST 2025] SEVIIN’s New Aluminum Dream – Elite-Level GX Series Baitcast Reels
- [ICAST 2025] The Ultra-Light KastKing Mg-Ti Baitcast Reel
- [ICAST 2024] YETI Roadie 32 Wheeled Cooler
- Machined Rigid Frame – Single-piece frame machined from 6061-T6 Aluminum
- Forged Sideplates – Forged and machine-cut aluminum left and right sideplates.
- Cold Forged Spool – Machined Aluminum Spool with Type-II Anodizing for corrosion resistance.
- XL Gearing – Oversized 303 stainless steel drive and pinion gear
- Flite Drive system increases gear stability and smoothness
- Carbonite Dual Force Drag system with Cal’s drag grease
- Triple Anti-reverse system – Two one-way bearings with ratchet A/R
- Spool Lock – For easily popping your line when stuck on the bottom
- Machined aluminum handle with EVA T-Bar knob
- CRC: Corrosion Resistant Coating process
- Right-handed or left-handed Models available
- Backed by a 3-year limited warranty from Okuma
- Bearings – 9BB + 2TB Stainless Steel Bearings
- Gear Ratio – 5.5 : 1
- Line Retrieve Per Crank – 40 in per crank
- Weight – 21 oz
- Braid Line Capacity – 20-lb/700 yds, 30-lb/600 yds, 40-lb/500 yds
- Max Drag – 26lbs at Strike, 46lbs at Full
- MSRP – $449.99
- Availability – July 2025
