- Apr 22, 2010
- BumFu*k, Egypt
Does anyone here liquid cool their pc? I am really considering putting this on my machine....
Overview
[FONT=Verdana, Arial]
[/FONT][FONT=Verdana, Arial](Also available in silver) The Exos-2.5 possesses triple 120mm fans and an extended heat exchanger for approximately 1000W of cooling capacity. Its powerful PMP-400 pump also better assists systems with multiple blocks, splitters, and other components that naturally reduce flow and pump pressure.
The Exos-2.5 features rear G 1/4 BSP threaded inlet and outlet nozzle sockets (nozzles are not included). This allows any Koolance G 1/4 BSP nozzle or threaded quick-disconnect to be added to the unit. Like all Exos systems, the Exos-2.5 will connect with any PC through a standard rear card slot. This is ideal to avoid any modification to the computer chassis.
NOTE: The included Exos Slot Adapter will accommodate tubing up to 3/8" (10mm) ID, 1/2" (13mm) OD. If using 1/2" (13mm) ID tubing, Koolance recommends the BKT-PC-G with your preferred nozzles.[/FONT]
Using a parallel hose configuration with tubing splitters will help maintain coolant flow rate when using Koolance blocks with smaller internal diameter nozzles, such as 1/4" (6mm).
Components Required
[/FONT][FONT=Verdana, Arial]Cooler kits such as the CPU, hard drive, and video/motherboard chipset are not included with Koolance systems. To operate the system at minimum, a CPU cooler is required. Other liquid components (such as the radiator, pumps, and LED display) come pre-installed.[/FONT]
Overview
- Variable pump speed via the front display
- Rear G 1/4 BSP inlet and outlet nozzle sockets
- Radiator fan speeds adjust automatically, or with 10 manual levels
- Blue reservoir LED lighting
- Top coolant fill plug
- Independently-variable alarm and safety shutdown temperatures on all three sensors!
- [FONT=Verdana, Arial]Adapted power connection - does not require an AC power outlet[/FONT]
- [FONT=Verdana, Arial]Optional attachment strap for systems "on the go"[/FONT]
Components Required
