- Apr 27, 2010
- Bethlehem, Georgia
Lowrance introduces a new series of lake maps bringing a new level of detail to inland lakes for the benefit of boaters and fishermen. Enhanced Lake Maps are based on data with 4 times the resolution of previous data. Shorelines show more features, including small inlets, and look just like the actual shorelines, not angular or generalized. Small islands are now included and bottom structure, including river and creek channels in reservoirs, can also be seen. Underwater features on man-made lakes reflect conditions prior to inundation of the lake. Best of all, these lake maps now show depth contours - with each contour labeled with its actual depth.
Select Enhanced Lake Maps will be available for free download. If combined with a FreedomMap™ or MapCreate™ map, the Enhanced Lake Map will seamlessly replace the existing lake data with the new higher resolution data. Just add it to your memory card*.
Note: Be careful not to exceed the memory limit of your digital memory card.
Select Enhanced Lake Maps will also include submerged structures (those maps marked below with a red asterisk *). Submerged structures generally include river and creek channels, ponds, streams, roads, foundations, railroads, pipelines, oil and gas wells, etc.
New maps will be added periodically, so check back often. If you do not find a lake here, please check the Fishing Hot Spots® Pro page for many more lake maps, along with added features, preloaded onto digital memory cards for a great price.
Enhanced Lake Maps are compatible with the following products and code versions: version 1.4.0 and higher code with the LCX-104C, LCX-19C, LCX-18C, GlobalMap® 7000C, GlobalMap® 6000C, GlobalMap® 5000C, GlobalMap® 4000M; version 3.1.0 and higher code with the LCX-16CI, LCX-15MT, LCX-15CI, GlobalMap® 3000MT; the GlobalMap® 3300C, GlobalMap® 4800M, LMS-330C and LMS-335CDF (any code version); version 1.3.0 and higher code with the GlobalMap® 3200, LMS-320, LMS-320DF; the iFINDER® Pro and iFINDER® H20 (any code version); version 1.6.0 and higher code with the iFINDER®; version 1.1.0 and higher code with the AirMap® 500; the AirMap® 1000 (any code version); and all 2006 or newer GPS products with MMC/SD memory card capabilities.
