Missile Drops the Bomba 3.5 and More Spunk Shads
The new Bomba 3.5 is dropping along with additional offerings of the Spunk Shad soft plastics from Missile Baits. The Bomba 3.5 is a soft plastic finesse bait worm with a thick crawfish pattern worm body and the thing skips like a rocket. Like a combination of a ned rig worm and Senko, the bait looks like a crawfish that got all its legs pulled off by a twisted little kid. There’s a hook slot molded into the belly of the lure so hook sets will be super easy with no plastic in the way. 3.5 Bombas should mostly be fished in a weightless Texas rig for an erratic fall through the water column, it will glide, rock, and even slide away from you at times before it reaches the bottom.
“The Bomba 3.5 is a simple bait but extremely deadly because of its subtle action and amazing castability. I love that you can use it on a spinning or bait casting setup, and it is basically snag resistant. It will be used by pros on tour to novices catching their first bass in a pond,” says John Crews, BASS pro angler and Missile Baits owner.
The Bomba 3.5 is going to be available in 8 colors including some tried and true Missile Baits colors and others being brand-new colors like Candy Crushed and Green Pumpkin Diablo. They’ll be 6 to a pack and should have a suggested retail price of $5.69 a bag. Perfect for when you need a finesse bait but still need to make a long cast to spooky fish. The Bomba 3.5 should be available to ship out starting July 24th of this year.
Missile Baits is also adding onto its Spunk Shad line of baits to grow its partnership with Hog Farmer Baits. The Spunk Shad 3.5 size option will be added to the existing 4.5 and 5.5 in the same 6 colors plus two more Missile Bait colors. All three sizes options of the Spunk Shads will have the colors Bombshell and Superbug available. These new Spunk Shads should be available starting September 2023.
The post Missile Drops the Bomba 3.5 and More Spunk Shads appeared first on OutdoorHub.
