- Apr 4, 2010
- Monticello, MN
I have a 1991 Stratos 201 PRO XL dual console, with a 1990 Evinrude 200XP. I bought it as a project boat. Anyways the VRO is disconnected, but the tank, hose, primer bulb, wiring, etc is still there. Where does the wiring hook up to? The engine, or by the Remote (i.e. throttle and ign switch)? Also I like Lilmule's idea of running an electronic pump for the oil. What pump would work for that?? I can handle the wiring part and everything else, just need to be pointed in the right direction. Also what are some of the things to look for on the engine for problems with the VRO system. Something about checking the hoses going to the nipples on the intakes or carbs??? What other types of things could someone install to help monitor the oil injection. I run mixed in the tank right now, but from reading a lot of the threads here and I would like to re-install system. Thanks
