Reel In the Fish with the Millennium Marine Rod Tree and Rod Pod
For some, fishing is more than a sport, it’s a legitimate way to put food on the table and enjoy the fruits of your labor. However, casting and keeping track of multiple lines is hard to do without a dedicated group of people aboard. That is why Millennium Marine has introduced the Rod Tree and the Rod Pod for holding multiple rods on your fishing boat. With the Rod Tree and Rod Pod, fishermen can run up to 3 rods on each side of the boat while avoiding line tangles for maximum efficiency.
Pearl, MS (May 12, 2021) – Trolling multiple rods is not a passive game. The old adage, “Trolling is not a relaxing activity,” certainly holds true when running multiple rods and driving the boat. The key to proper lure presentation and the avoidance of tangles is to use a rod holder system that permits precise planer board placement, even in rough water. The Millennium Marine Spyderlok Rod Tree allows fishermen to meticulously run up to three rods on each side of the boat in an exact pattern without fear of constant tangles.
The Millennium Marine Spyderlok Rod Tree is made from anodized, low-glare finish aluminum with stainless steel hardware, making it impervious to saltwater corrosion. The unique patented Spyderlok technology ensures precise, secure locking angles and infinite adjustment and alignment. Oversized tubes facilitate quick rod removal, and a durable rubber boot protects rod handles. The tubes have a specialized ridge in the bottom that prevents the rod from turning. The Spyderlok Rod Tree swivels 360 degrees and 180 degrees vertically and mounts to either the R-101 base plate or TS series track system. No tools are necessary.
The Spyderlok Rod Pod uses the same low-glare finish anodized aluminum and an oversized tube as the Spyderlok Rod Tree. The Rod Pod adjusts 360 degrees and 180 degrees vertically. These are built to quickly add or remove the Rod Pod with two knobs. No tool required. It easily mounts to either the R-101 or TS series track system. The Rod Pod allows anglers to clear space or refine presentations.
By utilizing the Spyderlok Rod Tree and Rod Pod in conjunction with planer boards, anglers can cover more water and put their offerings in front of more fish with unparalleled precision and ease. One-year warranty. MSRP for the Spyderlok Rod Tree is $209.99, and the Spyderlok Rod Pod is $96.99.
Spyderlok Rod Tree Features
Spyderlok Rod Tree Specifications
Spyderlok Rod Pod Features
Spyderlok Rod Pod Specifications
Millennium Marine has made a great product here with a solid construction, design, and material choices to provide fishermen with every advantage when casting multiple trolling lines. I especially like the tool-free design for adjusting the Rod Tree since that will play a big role in how quickly you can set up multiple poles and reduce the time you spend setting things up.
The post Reel In the Fish with the Millennium Marine Rod Tree and Rod Pod appeared first on OutdoorHub.
- All anodized aluminum construction, low glare finish
- Great for salt or freshwater
- Smooth and easy pole angle adjustment
- Easy two-knob removal
- Mounting plate is flush with carpet – no more stubbed toes
- No tools necessary for use
- Our patented Spyderlok technology ensures tight, secure locking angles
- Mounts with either the R-101 or TS series track system
- Useful ridge in rod holder bottom to prevent rod turning
- Stainless steel hardware
- Durable rubber boot to protect rod handle
- Large tubes make it easy to remove the rod, even with a fish
- Swivels 360 degrees and 180 degrees vertical
- Makes pulling planer boards a breeze
- 1-year warranty
- Material: Anodized Aluminum
- Size: 31” L x 6.5” W x 2.5” H
- Model No.: R-400-00
- MSRP: $209.99
- 1-year warranty
- Size: 14.5” L x 6.5” W x 2.5” H
- Model No.: R-401-00
- MSRP: $96.99
