Shimano Launches NEW 2025 Ultegra FD Spinning Reel
Shimano North America Fishing aims to elevate the standard for high-performance spinning reels with great value with the new 2025 Ultegra FD. Designed to meet the needs of anglers in both fresh and saltwater, the Ultegra FD is a blend of Shimano’s cutting-edge technology, long-lasting CoreSolid construction, and great value; all rolled into one sleek package of a spinning reel.
“The Ultegra FD is built for anglers who demand reliable performance and advanced features without breaking the bank,” said Bob Mahoney, Shimano Freshwater Marketing Manager. “It’s a reel designed to handle diverse conditions, from bass and walleye to leading inshore species, with the durability and smoothness that anglers can count on.”
The Ultegra FD is built around Shimano’s InfinityXross technology. This works to extend the gear teeth surface of the cold-forged HAGANE gear so it evenly distributes force across the mating surface. Giving the gearing enhanced durability for the life of the reel. Then, for seamless cranking power, the InfinityDrive technology reduces the friction between the spool shaft and pinion gear, so even under heavy load, the reel still winds effortlessly. On top of these premium features, the reel also comes with Shimano’s Anti-Twist Fin, a flexible polymer fin on the bail arm that helps ensure even line lay and reduces the possibility of wind knots occurring. Lastly, Shimano’s X-Protect technology protects the reel from water intrusion, making it a great choice for saltwater and freshwater anglers. All of this combined makes for a high-performance reel that should last season after season, with a more reasonable price point with an MSRP of $159.99 – $179.99, depending on the size.
Shimano 2025 Ultegra FD Spinning Reel Key Features
The post Shimano Launches NEW 2025 Ultegra FD Spinning Reel appeared first on OutdoorHub.
- 5 + 1 Ball Bearings
- InfinityXross – Extends the cold-pressed HAGANE gear tooth surface
- InfinityDrive – smooth, effortless winding — even under heavy load
- Anti-Twist Fin – Ensures even line lay on the spool and minimizes the occurrence of wind knots
- Hagane Gear – Cold-forged, extremely durable and wear-resistant alloy from Shimano
- X-Protect – Aids in preventing water from entering internal structures and helps reduce the risk of corrosion
- Gear Ratio – 5.1:1, 5.8:1, 5.8:1, 6.2:1, 6.2:1
- Weight – 6.3 oz, 7.6 oz, 7.8 oz, 9.3 oz, 9.7 oz
- Max Drag – 7lb, 20lb, 20lb, 24lb, 24lb
- Reel Sizes – 1000, 2500, 3000, 4000, 5000
- MSRP – $159.99 – $179.99
