Slice and Dice: The NEW Gerber Ceviche Fillet Knife
Have you ever tried to fillet a fresh-caught fish with a field knife? If so, I don’t have to tell you how much easier it is to carve up your catch with a proper fillet knife. The long, thin, sharp and flexible blade seems to glide right through the fish and over the bones, setting you up for quite a meal. If you’re in the market for a new fillet knife, Gerber has you covered. Just released, these are both the 7″ and 9″ versions of the new Gerber Ceviche fillet knife.
Gerber Coverage on OutdoorHub
When you’ve just caught your next meal, you demand a fillet knife that expertly handles that precious catch. The Ceviche
is the no-fuss, task-specific blade you need on deck to handle the cleaning of everything from pan fish to trophy-sized Walleye.
The Gerber Ceviche fillet knife is available in two different lengths. One has a 7.14″ blade, while the other has a 9.18″ blade. The 5Cr stainless steel blades are coated in Salt Rx to increase corrosion resistance. The grips are textured to prevent your wet hands from slipping. Included with the knives is a vented sheath to keep your sharp edge sharp. The grip ends in a lanyard hole so you can connect the knife to yourself so it isn’t lost if dropped.
SPECS
If you’d like to check these out for yourself, you can order either version from the Gerber website. You can also get more content from the company by liking and following on social media. Gerber can be found on Facebook, Instagram, Twitter, and YouTube. Get those fires going!
The post Slice and Dice: The NEW Gerber Ceviche Fillet Knife appeared first on OutdoorHub.
- The NEW Devour Titanium Multi-Fork From Gerber
- The Gerber Sedulo is the Second Blade to be Offered in the Gerber Reserve Program Featuring Exclusive American-Made Knives
- Gerber and Randy Newberg Team Up to Develop a Line of Field Dressing Tools
SPECS
- Overall length: 12.43″ (7″), 14.46″ (9″)
- Weight: 3.1 oz, 3.33 oz
- Blade material: 5Cr stainless steel
- Blade length: 7.14″, 9.18″
- MSRP: $25.00, $30.00
