Spring with Fishing Essentials from H2OX at Academy Sports
While the groundhogs said we got six more weeks of winter this year, that just means we got 6 more weeks to prep for Spring Fishing this year. To help you get started on that is H2OX at Academy Sports + Outdoors with just about everything you need to get started. Be it prepping for your first spring of fishing or your 20th, Academy Sports + Outdoors has plenty of Fishing Essentials you can use this year to get into that spring bass bite.
Spring Fishing Essentials – Rods & Reels
H2OX Premier Spinning Combo With Finesse Bait Kit
H2OX Premier Spinning Combo With Finesse Bait Kit MSRP – $49.99
The H2OX Premier Spinning Combo with Finesse Bait Kit is a great all-around combo for anglers of all skill levels. This is a 1-piece 7′ IM6 graphite spinning rod, matched with a lightweight composite spinning reel with a machined aluminum spool. This combo is built around effortless finesse presentations for catching the most finicky of fish, like pressured bass on beds.
H2OX Premier Baitcast Combo With Frog Bait Kit
H2OX Premier Baitcast Combo With Frog Bait Kit MSRP – $79.99
The H2OX Premier Frog Rod and Reel Combo are purpose-built for throwing frogs into heavy cover and lilypads and ripping them through. A 7′ 3″ with heavy power and fast action has the backbone needed to set the hook on big bass, blowing up the supplied frogs. The reel features a 7.3:1 gear ratio for quick retrieves. This topwater combo will work for anglers of all skill levels and won’t break the bank.
H2OX Evo Baitcast Reel
H2OX Evo Baitcast Reel MSRP – $99.99
The Evo baitcaster from H2OX is a tournament-quality reel designed in partnership with BASS Elite Series Pro Stetson Blaylock. This reel has a durable 1-piece aluminum frame, lightweight carbon side plates, a centrifugal brake system, and a hinged side plate for easy access for maintenance and tuning.
Spring Fishing Essentials – Accessories
H2OX Premium Bait Locker
H2OX Premium Bait Locker MSRP – $19.99
The H2OX Premium Bait Locker is perfect for organizing and protecting your baits this spring. It is a great tackle storage solution with quality latches, adjustable dividers for custom layouts, a sealing gasket, and built-in rust protection. It has a VCI rust inhibitor in the plastic to keep your lures in tip-top shape.
H2OX 19 Qt Bait Cooler
H2OX 19 Qt Bait Cooler MSRP – $59.99
Keep your pricey live baits perky with the H2OX 19 Qt Bait Cooler; this cooler has a built-in aerator that helps keep your bait fish alive and cool even as the weather warms up. This durable little livewell cooler comes with a bait basket to quickly get bait out of it and secure double latches to help seal the cooler so you don’t spill minnow water inside your vehicle. These come with a rechargeable or battery-powered aerator, a comfortable shoulder strap, and a top compartment for added storage.
H2OX 3700 Evo Soft Tackle Bag
H2OX 3700 Evo Soft Tackle Bag MSRP – $89.99
The H2OX 3700 Evo Soft Tackle Bag is a quality tackle bag loaded with high-end features. For efficient organization, it has a compression-molded top and a quick-access storage slot. The bottom of the bag is also compression-molded to be waterproof and durable, so your five included 3700 utility boxes and 3600 top trays stay high and dry while you’re fishing.
Spring Fishing Essentials – Baits
H2OX 4 Inch Prerigged Swim Baits
H2OX 4 Inch Prerigged Swim Baits MSRP – $3.99
The H2OX 4″ Prerigged Swimbaits are designed for anglers of all skill levels. These swimbaits feature a realistic sculpted shape and lifelike 3D eyes to trigger more bites. These lures are ready to fish straight out of the package, equipped with a premium hook for reliable performance.
H2OX Curly Leg Frog Baits 3-Pack
H2OX Curly Leg Frog Baits 3-Pack MSRP – $5.99
Bring in hungry bass with the enticing action of the H2OX Curly Leg Frog Baits 3-Pack. These weedless baits have been designed to be versatile and capable of being fished in heavy cover with ease. They feature a slow-sinking action that is perfect for subsurface action or skipping under docks.
H2OX 3-Piece Hollow Body Frog Bait Kit
H2OX 3-Piece Hollow Body Frog Bait Kit MSRP – $10.99
The H2OX 3-Piece Hollow Body Frog Bait Kit has an expert-approved design mated with cutting-edge tech to make a perfect topwater frog that any angler can use. These frogs look great, having a lifelike natural design and flowing silicone skirt legs for added action. The hooks are razor-sharp 3/0 Eagle Claw double hooks that will give you the best chance of pinning that big bass blow-up.
The post Spring with Fishing Essentials from H2OX at Academy Sports appeared first on OutdoorHub.
