The New and Improved Pflueger Trion Spinning Reel
Pflueger, an industry name that anglers have known and trusted for decades now, has brought out a new and improved version of the Pflueger Trion Spinning Reel for 2025. Continuing the legacy of previous iterations, this new generation of spinning reels is made to be ready to handle any challenge it may face, regardless of the conditions. Aiming to be top of its class in terms of value and versatility, the 2025 Trion spinning reel is a very budget-friendly reel option that comes loaded with features.
The redesigned Pflueger Trion spinning reels still retains the smoothness anglers expect from a Pflueger, but now enhanced with the Total Line Control system. This feature allows anglers to use any type of fishing line, mono, braid, or fluoro, while minimizing line twist and wind knots. The main body and rotor of the reel are constructed of lightweight graphite, sporting an aluminum handle with a soft-touch handle knob. The spool is made from aluminum and is braid-ready, so no need for mono backing. Additionally, for better line lay and casting distance, the Trion now features a slow oscillation design. For bearings, it has a 6+1 system, except for the 20 size, which is a 4+1, for consistent and smooth retrieves. These new reels are available in five sizes (20, 25, 30, 35, 40). The Trion lineup offers a perfect match for a wide range of freshwater techniques and conditions. MSRP for the reel is set at $64.99 and is available now.
Pflueger Trion Spinning Reel Key Features
  • Lightweight graphite body & rotor
  • Total line control system-reduced line twists and wind knots
  • Slow oscillation
  • Aluminum braid ready spool
  • Aluminum handle with soft-touch handle knob
  • 20, 25, 30, 35, 40 sizes available
  • Bearings – 4+1 (20), 6+1
  • Gear Ratio – 5.2:1
  • Line Retrieve Per Crank – 39.5″ (15, 20, 30), 47.4″ (35, 40, 50),
  • Mono Line Capacity – 12/310(15), 12/400(20), 14/490(30), 20/300(35), 25/400(40), 30/350(50)
  • Braid Line Capacity – 30/330(20), 40/330(25), 40/450(30), 50/390(35), 65/480(40)
  • Max Drag – 6lb (20), 8lb (25), 10lb (30), 12lb (35), 14lb (40)
  • MSRP – $64.99
  • Availability – October 2025
The post The New and Improved Pflueger Trion Spinning Reel appeared first on OutdoorHub.
