The PENN Rival II Reels – New and Improved and Ready for Battle
PENN is here to get anglers who live for fishing the salt ready for battle with the new PENN Rival II level wind conventional reels and Rival II level wind conventional combos. Reworked with better engineering and components, the new Rival II reels feature a lightweight graphite frame and sideplates, a marine-grade bronze alloy main gear, and a machine-cut brass pinion gear. The drag system of the reel uses the PENN HT-100 carbon fiber drag system for a smooth and consistent drag that performs even under heavy load, with a max drag of 15lbs (7kgs). Additionally, for added convenience to anglers, the reels come with auto-engaging gears and line capacity rings for easy and intuitive operation. Lastly, for added longevity and smoothness for the reel, the two bearings are shielded stainless steel bearings that will hold up to the saltwater season after season. The new Rival II level wind conventional reels are available in 3 sizes, 15, 20, 30, and in a standard or line counter model. MSRP ranges from $94.99 to $139.99, depending on model.
Along with just the reels, PENN is offering the Rival II Level Wind Combos. This matches the reels with PENN rods that come equipped with Dura-Guides and triangular EVA foregrips. Each combo is factory-matched to deliver a balanced and smooth fishing experience for saltwater anglers. MSRP for the combos ranges from $139.99 to $159.99, depending on the model.
PENN Rival II Level Wind Conventional Reel Key Features
  • Lightweight graphite frame and sideplates
  • Auto-engaging gears
  • Marine-grade bronze alloy main gear
  • Machine-cut brass pinion gear
  • HT-100 carbon fiber drag washers
  • Line capacity rings
  • Line Counter Model Available
  • Left or Right Hand Retrive Models Available
  • Bearings – 2 Shielded Stainless Steel BB
  • Gear Ratio – 5.1:1 (15), 5.1:1 (20), 3.9:1 (30)
  • Fluoro Line Capacity – 375/12 (15), 475/15 (20), 455/25 (30)
  • Braid Line Capacity – 580/20 (15), 865/20 (20), 1020/30 (30)
  • Max Drag – 15 lb (15), 15 lb (20), 15 lb (30)
  • MSRP – $94.99 – $119.99 (W/O Line Counter), $109.99 – $139.99 (W Line Counter)
  • Availability – October 2025
  • HT-100 drag washers provide smooth drag under heavy loads
  • Machined brass main and pinion gear
  • PENN Dura-Guides
  • Triangle EVA foregrips
  • Rod Power – Medium, Medium Heavy
  • Rod Length – 5′, 6’6″, 7′
  • Rod Pieces – 1 Piece
  • MSRP – $139.99-$159.99
The post The PENN Rival II Reels – New and Improved and Ready for Battle appeared first on OutdoorHub.
