The Star Drag Reel Elevated – Daiwa 2025 Saltist SD
Daiwa has come a long way with its star-drag reel tech since the 1960s Millionaire reel. Always improving upon their work, Daiwa has brought out the new feature-rich and rugged 2025 Saltist SD conventional reel. This new reel comes with a solid machined aluminum frame and side plate for added rigidity and durability. The aluminum side plate also now screws into the frame to increase the integrity of the reel further and help keep water and grit out of the reel. Daiwa has also kept anglers who prefer casting with conventional reels in mind, with the new dynamo braking system. A centrifugal braking system that helps reduce spool overrun and backlashes. The new 2025 Saltist SD is available in six sizes (15, 20, 30, 35, 40, 50), and has an MSRP range of $279.99 to $309.99 depending on the size.
“The new SALTIGA SD promises to be that foundational and trustworthy reel in your saltwater collection,” said DAIWA Field Marketing Manager, Chris Martin. “It’s a reliable, value packed reel for saltwater jigging, casting jetties and surfcasting.”
Daiwa 2025 Saltist SD Conventional Reel Key Features
The post The Star Drag Reel Elevated – Daiwa 2025 Saltist SD appeared first on OutdoorHub.
- A Bass Unique to the Ozarks – The Neosho Bass
- Emil Wagner Wins at Bassmaster Elite Qualifier on Lake Champlain
- Same Trusted Action in Shallow Water Form – Berkley Shallow Money Badger
- One-Piece Aluminum Frame & Sideplate – The frame and sideplate are machined from high-strength diecast aluminum for rigidity and strength. The Sideplate is threaded and screws directly into the frame to improve integrity and prevent water and debris intrusion.
- Centrifugal Casting Brake –Small weights are attached to the spool that move outward due to centrifugal force as the spool spins during a cast and contact the brake drum to help slow the spool and prevent backlashing.
- Digigear –DAIWA’s digitally cut, machined gearing system ensures precise meshing of the main gear and pinion gear, which results in exceptional smoothness and vibration control, increased durability, and efficient power transfer from the handle to the rotor.
- Waterproof Carbon Drag ATD (Automatic Tournament Drag) – Daiwa’s Automatic Tournament Drag uses an improved drag grease that exhibits a low viscosity at rest, yet becomes more viscous immediately after drag start-up.
- Bearings – 4CRBB, 1RB
- Gear Ratio – 6.4:1
- Line Retrieve Per Crank – 39.5″ (15, 20, 30), 47.4″ (35, 40, 50),
- Weight – 15.9 oz(15), 16.6 oz(20), 16.9 oz(30), 21 oz(35), 21.3 oz(40), 22 oz(50)
- Mono Line Capacity – 12/310(15), 12/400(20), 14/490(30), 20/300(35), 25/400(40), 30/350(50)
- Braid Line Capacity – 30/330(15), 40/330(20), 40/450(30), 50/390(35), 65/480(40), 80/460(50)
- Max Drag – 17.6lb (15, 20, 30), 22lb (35, 40, 50)
- MSRP – $279.99 to $309.99
- Availability – Available Now
