http://www.tritonaluminum.com/
http://www.tritonaluminum.com/dealer-list/
Built to hunt, primed to fish. A boat for all seasons.
Specifications
Length17'Beam80"Bottom Width56"Hull Gauge.100"Transom Height20"Approx. Weight (lbs)605 lbsMax. Persons Capacity5/750 lbsRecommended Horsepower Range40-60 hps
OPTIONS
Specifications
OPTIONS
- Open All
- Close All
- <LI sizcache="11" sizset="3">Colors
- OD Green
- Real Tree® Hardwood
- Mossy Oak® Break-Up
- Mossy Oak® Shadow Grass
- Real Tree® Max 4
- Mercury Jet 25 ELH GA EFI (Requires Jet Mod-Remove Center Strake)
- Mercury 25 ELH EFI
- Mercury 25 ELHPT EFI
- Mercury 30 ELH EFI GA
- Mercury 30 ELHPT EFI
- Mercury 40 ELH EFI
- Mercury 40 ELHPT EFI
- Mercury 50 ELHPT EFI
- Mercury 60 ELHPT EFI
- Miscellaneous
- Camo Backout
- Jet Modification (remove partial center strake)
- Performance Wedges
- Bilge Pump (manual)
- Auto Bilge Pump assembly
- Transducer Bracket (welded on)
- Trolling Motor Harness (24 volt- 6 gauge)
- Trolling Motor Harness (12 volt- 8 gauge)
- Motorguide FW 46 FB 42 (assembly)
- Tempress Seat with Cushion
- Seat Clip (male)
- Lock-Track Shotgun Shell Holder
- Lock-Track Tree Clamp
- Extra Base Plate (must have location)
- Spare Tire-13" Galvanized
- Spare Tire-13" Silver
- Ratchet Tie Downs
- Galvanized Trailer Upgrade-15'-16'-17'
- Swing Tongue Assembly
- Trailer Backout 1756 DS/SC
- Open All
- Close All
- <LI sizcache="11" sizset="8">Fishing Features
- Low Casting Deck
- Rod Box
- Bow Storage
- Standard Trailer
- Single Axle Trailer
- Loading Guides
- 13" Silver Directional Wheels
- Spare Tire Carrier
- NMMA Certified
- Some engines for "tiller" model boats may not have a handle. Check the Engine Mfg.
- Removable Anchor Light and Nav. Light
- Upright and Level Flotation
- NMMA Certified
- Seat-Clip (Male standard)
- Seat-Clip (Female standard)
- Wing Seat
- Gun Box W/Cushion
- 2-Camo Seats
- Wood Free
- Stainless Steel Bow and Stern Eyes
- Over Sized Center Keel
- Lock Track Extruded Gunwales
- Extruded Extra Strength Ribs
- All Welded Construction
- 5052 Aluminum
- 1-1/4" Strakes
- Finish and Flooring Features
- SPRAY - Liner (Spray On) W-Camo
- Real Tree Camo Hardwood
- Mossy Oak Shadow Grass
- Mossy Oak Camo Break-Up
- Floor and Side Skins
