- Aug 9, 2010
- Coral Springs, Florida
Still exploring the Humminbird unit but I thought I saw a voltage alarm feature on it. Does anyone use this function? Does it warn you if voltage drops too low on the cranking battery?
I could see how it could be pretty useful if you had livewells running and electronics running while you are on the Trolling Motor. I guess it could save you from running the battery down to low to where it wouldn't start. If you use this funtion what do you set the alarm to for warning? Also how much time do you usually get with everything on before you start worrying about your battery getting drained?
