- Apr 27, 2010
- Bethlehem, Georgia
Inspect gear lubricant for metal particles (lubricant will have a 'metal flake' appearance). Drain lube into a clean pan/container. The presence of fine metal particles (resembling powder) in the gear lube indicates normal wear. The presence of metal chips in the gear lube indicates the need for gear housing disassembly and component inspection by an authorized dealer.
Note color of gear lubricant when draining. If the color is white or cream it MAY indicate the presence of water in lubricant. Gear lubricant which has been drained from a gear case recently in operation will have a yellowish color due to lubricant agitation/aeration. Gear lube which is mixed with assembly lubricant (Special Lube 101 or 2-4-C w/Teflon) will also be creamy white in color. This is normal and should not be confused with the presence of water. If water is suspected to be present in the gearcase, a pressure check of the gearcase should be completed by an authorized dealer. Pouring a portion of the gear lubricant into a glass jar and allowing the lubricant to settle will allow any water in the lube to separate and settle to the bottom of the jar.
Presence of water in gear lubricant indicates the need for inspection by an authorized dealer. The dealer will disassemble the gear housing and inspect the oil seals, seal surfaces, O-rings, water pump gaskets, as well as the gear housing components for damage.
From the Mercury webpage: http://www.mercurymarine.com/servic...nance/faqs/parts-and-accessories/#Aftermarket
