Whitewater Basin Deck Boot – From Deck to Dock
Trusted foul-weather gear maker Whitewater Fishing is here with the new Basin Deck Boot, a 100% waterproof deck boot priced at $100. This is a new set of deck boots designed for long hours on the water and unpredictable elements. Offering an easy-on and easy-off boot style that remains a secure fit, these new boots feature a durable and slip-resistant outsole with a custom pattern that channels water away while enhancing traction. Inside the boots, there are supportive Polyurethane (PU) insoles that provide superior cushioning and support to keep you comfortable for long days on deck. To keep your feet dry and reduce odors, there is an antimicrobial and moisture-wicking treated liner. The actual boot body is made from a premium rubber material that has been vulcanized around a neoprene bootie. For added durability, the heel body is double-layered, and the toe features a checkered rubber layer. For added ease of removal, there is even a molded rubber “kicker” outcropping for quick removal of the boots. The Whitewater Fishing Basin Deck Boots are available for purchase now with an MSRP of $100. Sizes are available from men’s 8 to 13 and in the color Shade gray.
“We truly took every use, condition, and inch into consideration,” said Whitewater Merchandise Manager, Doug Veldhuizen. “And the boot’s slip-resistant sole really demonstrates our attention to detail and the boot’s ultimate performance.”
Whitewater Basin Deck Boot Key Features
  • 100% waterproof
  • Textured slip-resistant sole
  • Sole is channeled to shed water
  • Premium rubber body
  • Reinforced heel and toe
  • Molded kicker for quick removal
  • Dual web loops for easy-on
  • Mildew-proof, antibacterial, and moisture-wicking treatment
  • Contoured polyurethane insole with arch support
  • Sizes – 8 – 13
  • Colors – Shade
  • MSRP – $99.99
  • Available – Available Now
The post Whitewater Basin Deck Boot – From Deck to Dock appeared first on OutdoorHub.
