OptiMax 115 Pro XS Specifications
HP @ Prop115kW @ Prop84.6Max RPM (WOT)5000-5750Cylinders3 (in-line)Displacement (CID/cc)92.96/1526Bore & Stroke (in)3.63 x 3.00Bore & Stroke (mm)92 x 76Cooling SystemWater-cooled with thermostat & pressure-controlledIgnition SystemPCM 07StartingElectricGear Ratio2.07:1Gear ShiftF-N-RSteeringRemote or tiller kitAlternator60-amp/756-watt belt-drivenTrim SystemPower trimExhaust SystemThrough propLubrication SystemElectronic multipoint oil injectionRecommended OilMercury OptiMax/DFI Engine OilFuel Induction System2-stage direct fuel injectionShaft Length (inches)20Shaft Length (mm)508Dry Weight (lbs.)375Dry Weight (kg.)170Operator Warning SystemOverheat, over-rev, low oil levelSmartCraftYes $7995.00 per merc retailWarranty3
