Double your Kayak Rod Holders with the Dual Action Rod Troller – D.A.R.T.
At the NOEoutdoors Fishing Expo this weekend I found a cool new way to get more functionality out of your swiveling rod holders. The new Dual Action Rod Troller – D.A.R.T. is a new accessory that can mount to most swiveling rod holders like a Scotty and double its rod holding capability along with giving you a mounting platform. This is great for kayak fishing where space if a always at a premium. Add to that most kayaks have rod holders behind the angler this can make your life easier by placing two rod holders in front of the angler. The Dual Action Rod Troller – D.A.R.T. fits into most styles of external swiveling rod holders to give you two additional adjustable rod holders. As well as a platform between the rod holders to either put the supplied tackle box or mount other accessories too. Most other accessories also do not need any drilling to mount, as there are already holes molded into the accessory body
The Dual Action Rod Troller – D.A.R.T. bady and rod holders are made from injection-molded HFPE, while the tackle box lid is made of UV-resistant and durable urethane. Both of these components are locally made in the USA with care. The supplied tackle box lid also comes with magnets built in so you can easily just have it open partially so your tackle is easily securable as you fish. The D.A.R.T. rod holders are available now and have an MSRP of $45 for each unit. Check them out here if interested.
Dual Action Rod Troller – D.A.R.T. Key Features
  • Fits to any model of standard kayak rod holder
  • Multiple mounting options with the built-in mounting holes in the D.A.R.T. body
  • Rod holders can be adjusted to different angles
  • Body and Rod holders made from Injection Molded HDPE (High-Density Polyethylene)
  • Tackle Box comes with a durable Urethane lid with magnets built in.
  • Made in the USA
  • MSRP – $45
  • Available Now
The post Double your Kayak Rod Holders with the Dual Action Rod Troller – D.A.R.T. appeared first on OutdoorHub.
