- Nov 18, 2009
- SW MO
Humminbird 898c - Color, GPS, Mapping, DualBeam 2D, Side Imaging and Down Imaging
There are two units in the 800 series: the 898c SI, side imaging sonar/GPS combo, and the 858c sonar/GPS combo that is not side-imaging equipped.
Some pertinent features for the new 898c SI combo include:
• Side Imaging™, Down Imaging™, and DualBeam PLUS™ Sonar for unmatched sonar performance.
• Brilliant 480V x 800H, 7” diagonal color TFT display
• New SwitchFire™ Sonar allows two ways to view returns - Clear or Max mode.
• Three new color palettes for more viewing options
• New Built-In Contour XD™ Cartography from Navionics® with 3,000 U.S. lakes
• LakeMaster® compatible with exclusive features
• Waypoint Management allows more control of your saved data.
• 4000 Watts Peak-to-Peak, 500 Watts RMS power output
• External 50 channel WAAS GPS receiver included
• Tidal graphs and port services information available with optional Navionics® Charts
• Sonar/chart recording to SD card and on-screen playback
• Full screen chartplotter, 3D birds eye view chartplotter and split screen sonar/chart with adjustable split
• Programmable view presets access important screens with one touch
• In-dash or gimbal mount
• Water surface temperature included in transducer, GPS speed Included
• Optional LakeMaster®, Navionics® Gold, HotMaps, and HotMaps Premium, and Platinum+ cartography
• SwitchFire™ Max Mode shows every sonar return from fish to zooplankton; Clear Mode reduces noise to show only structure & fish
• Fresh and saltwater set up options for optimal performance in any environment
• Accelerated Real Time Sonar™ operates at up to 40 times per second to instantly capture the action under the boat
• X-press™ menus place most important setting at your fingertips
• Freeze Frame pauses the sonar scroll for detailed inspection of the screen
• Instant Image Update immediately shows the results of setting changes for the most accurate fine tuning
• Sonar Echo Enhancement™ technology is so sensitive it’ll track a 1/2 oz. jig to over 40ft and separate targets within 2 ½ inches
• Man Overboard Function quickly adjust the boat track back to a specific spot with the touch of a button
• Fully gasketed waterproof design and it floats
• Large Digital Data displayed on every sonar or GPS screen
• Backlight for night viewing
• TripLog with distance, elapsed time, and average speed
• Totally automatic operation or totally manual operation with upper and lower range control
• Temperature graph overlay and audible temperature alarm along with One-touch Zoom with 2x, 4x, 6x, and 8x zoom levels
• Adjustable chart speed and feature memory retains your settings
• Water surface temperature included in transducer, speed paddlewheel included
• PC Connection capability to save waypoints, and upgrade internal software
• Optional 200/50kHz transducer available for deep water applications and depths to 3000 feet MSRP on the 898c SI combo is $1499
MSRP on the 858c combo is $999
