Smartcraft at a Glance
Accurate digital information in a clean, easy-to-read gauge. Mercury SmartCraft gauges provide you instant, reliable information at a glance. Combined with additional sensors, Mercury's digital gauges are powerful tools to provide safety and comfort while on the water.
AVAILABLE VESSEL INFORMATION
- Troll Control™
- Fuel to Waypoint
- Engine Synchronizer
- Trim Synchronizer
- Steering Angle
- GPS Speed
- GPS Course and Speed
- Speed Sensor Fault
- Low-Fuel Warning
- Low-Oil-Level Warning (outboard)
- Water in Fuel Fault
- Auto Speed Sensor Transition
- Air/Sea Temp
- Digital Speed
- Oil Level
- Fuel Level
- Time of Day
- Boat Speed
- Low Depth Warning
- Horn Fault
- Ignition Fault
- Injector Fault
- Oil System Fault
- Reserve Oil (outboard)
- Dot Matrix LCD display
- RPM
- Engine Alarms
- Oil Temp
- Battery Voltage
- Depth
- Water Pressure
- Coolant Temp
- Coolant Pressure
- Engine Hours
- Trim Pop-Up
- Engine Trim
- Fuel Used
- Fuel Flow
- Fuel Range
- System Link Gauge Connection
FUEL MANAGEMENT WITH SC1000 GAUGES
- Take the guess work out of performance and maximize you boat's fuel economy with fuel information available from the SmartCraft Network displayed on SC1000 gauges.
- SC1000 guages will display your boat's Trim, RPM and Speed data to determine your engine's fuel economy.
- The result of the SmartCraft capabilites is a real-time calculation and display of your engine's instant and average fuel efficiency.
The marine industry's most advanced gauge offering essential vessel information in plain, descriptive language.
