Plano’s NEW EDGE 3700 Swimbait Box
Plano Outdoors has brought out a new flat-pack tackle box to add to the EDGE line. The new Plano EDGE 3700 Swimbait box has been made to be the new standard when it comes to protecting and organizing swimbaits. Made to change up the swimbait storage world, the EDGE 3700 Swimbait box can hold up to 24 swimbaits in a horizontal position or 10 in a vertical position. All in a reliable and secure tackle box. When used as vertical storage this tackle box suspends swimbaits and glide baits in the air, keeping the baits separated and shielded during storage and transit. Swimbaits and glide baits often have soft tails that get deformed when stored horizontally causing their swimming action to suffer.
Plano uses advanced Rustricor corrosion and rust-preventive technology in the plastic of the EDGE 3700 Swimbait box to give anglers the ultimate rust and moisture protection for their often pricy swimbaits. The EDGE 3700 Swimbait box also comes equipped with a Dri-Loc O-ring watertight seal to guarantee the box against any moisture intrusion when it is latched and closed. To deal with the moisture that has already made its way inside the WaterWick divider with its moisture-wicking packets will keep things dry. For convenience, the new EDGE tackle boxes all come with the EZ Label system for easy organization of your swimbaits. The DuraView crystal-clear transparent polycarbonate lid of the tackle box make for easy visual identification as well. The Plano EDGE 3700 Swimbait box should be available now and have an MSRP of $49.99 a tackle box.
Plano Edge 3700 Swimbait Box Key Features
  • Dri-Loc O-Ring watertight seal
  • WaterWick divider with a moisture-wicking packet
  • EZ Label system for effortless organization
  • DuraView transparent polycarbonate lid
  • 360 degrees of Rustrictor rust prevention technology
  • Dimensions: 14″L x 9″W x 2.63″H
  • MSRP: $49.99
  • Available: October 2023
The post Plano’s NEW EDGE 3700 Swimbait Box appeared first on OutdoorHub.
