6 Last Minute Christmas Fishing Gifts
We have less than a week till Christmas, it’s practically here. So if you have an angler in your life who you haven’t gotten a Christmas gift for yet and don’t know where to start, we got you covered here. Here are 6 last-minute fishing gifts that might be exactly what you’re looking for. No matter their skill level, from pro anglers to first-time anglers, these could be the ticket. Broken down into three different price points so no matter your budget there should be something that fits into it here.
Fishing Christmas Gifts under $100
H2OX Evo Baitcast Reel – $99.99
Made in partnership with BASS Elite Series Pro Angler Stetson Blaylock, this is a tournament-grade baitcaster. Built on a robust 1-piece aluminum frame, the reel features strong but lightweight carbon side plates that are hinged for easy access to the internals. The reel has a centrifugal brake system that prevents backlash. The reel is available in two gear ratios 7.3:1 and 8.1:1.
  • Durable 1-piece aluminum frame
  • Lightweight and durable carbon side plates
  • Centrifugal brake system to prevent backlash
  • Hinged side plate allows for easy access
H2OX 3700 Evo Soft Tackle Bag – $59.99 (Save $30)
Loaded with high-end tackle bag features but coming in at an affordable price this tackle bag is a solid option. It comes in preloaded with five 3700 plastic tackle trays and one 3600 tackle tray. The top and bottom of the bag are made of durable compression-molded material, with the bottom being a solid waterproof piece. This tackle bag is built to last day after day in any conditions you go fishing in.
  • Compression-molded top for easy access
  • Quick bay open storage slot
  • Waterproof compression molded bottom
  • Comes with five 3700 utility boxes and one 3600 in the top tray
  • Made from 600D Polyester, Plastic, and Mesh Fabric
Fishing Gifts under $50
Magellan Outdoors Pro Leakproof 12-Can Square Cooler – $47.99 (Save $12)
Staying hydrated on the water is important, especially in the warmer months of the year. This 12-Can Square cooler can help with that, by making sure your drinks stay cold and not fishy. It is made with a durable 840-denier nylon shell, double-sided TPU lamination, and heavy-duty, watertight zippers. This cooler won’t leak and hold up season after season.
  • Designed for cold storage of beverages
  • 840-denier nylon shell with double-sided TPU lamination delivers lasting durability
  • Welded construction locks cold air inside
  • Heavy-duty, watertight zippers and buckles protect against leaking or spilling
  • A removable bottle opener allows for easy opening of your drinks
  • Structured front accessories pouch offers dry storage of your items
  • Cooler floats even when full
  • Holds 12 cans
  • A padded shoulder strap allows for comfortable transportation
  • 11 inches H x 14.5 inches W x 11 inches L
Magellan Outdoors Men’s Fishing Shore and Line Coastal Pants – $34.99
A quality pair of fishing pants makes a long day on the water a lot more enjoyable for anglers. These are made with Nanotex speed-dry water repellency and Flex technology for comfort and to keep anglers dry even on the longest days. These pants will also repel stains, come with 4 pockets, and have a UPF 50 protection rating to protect you from the sun.
  • Nanotex speed-dry water repellency
  • UPF 50 protection
  • Flex technology
  • Stain repellent
  • 4 pockets
  • Tapered leg
  • Adjustable drawstring waistband
  • Made of 86% polyester and 14% spandex
  • 32-inch inseam
Fishing Gifts under $25
Magellan Outdoors Men’s FishGear Mossy Oak Whitecap Long Sleeve Crew T-shirt – $24.99
A long-sleeved fishing shirt can save you during a long day on the water, be it from the sun or the heat. This shirt is made of a moisture-wicking flex fabric that will keep you cool even in the summer heat and humidity. The shirt also offers UPF sun protection to keep the UV rays off you and comes in Mossy Oak camouflage print for a stylish touch.
  • Made of 92% polyester and 8% elastane fabric with flex technology to let you move comfortably
  • Wicks away sweat to keep you feeling fresh
  • Cooling technology helps manage your body temperature
  • Provides UPF sun protection
  • Long sleeves
  • Crew neck
  • Mossy Oak Whitecap camouflage adds a rugged look
H2OX Premium Terminal Tackle Utility Box – $9.99 (Save $5)
Flat-pack tackle trays are the bread and butter of tackle storage for anglers. This box blends advanced technology with a budget-friendly design making it a great fishing gift to give to anglers.
  • Features pro latches and adjustable dividers treated with VCI rust inhibitor
  • Built to store lures, bait, tackle, and other fishing essentials
  • Made from ABS, plastic, and steel
The post 6 Last Minute Christmas Fishing Gifts appeared first on OutdoorHub.
