Abu Garcia’s Premium Zenon MG-X Spinning Reel
Abu Garcia has finished filling out their Zenon premium line of spinning reels with the new Zenon MG-X. This is Abu Garcia’s ultimate design for meeting the needs of finesse anglers. The reel has been made for anglers who want a premium spinning reel that weighs as light as possible to be matched with an ultra-sensitive lightweight rod. The Zenon MG-X is built around its one-piece asymmetric frame design. This is made of Abu Garcia’s X-Mag magnesium alloy, which gives the reel extra strength and weight savings. The spool of the reel has a mid-arbo air fin design for weight savings along with a rocket spool lip design for better line control as it comes off the spool. Features like these as well as many others are all steps taken by Abu Garcia to deliver unparalleled performance in a finesse spinning reel.
The lightweight and compact Zenon MG-X is available in two sizes: a 2500 and 3000 size reel. Both come with a 6.2:1 gear ratio using the AMG gearing system, to provide unparalleled smoothness and durability. The MSRP for both sizes of the reels comes in at $399.95 and are available for purchase now.
Zenon MG-X Spinning Reel Key Features
  • 10 stainless steel HPCR
    bearings + 1 roller bearing provides increased corrosion protection
  • One piece X-Mag
    alloy frame provides a super light yet extremely strong frame
  • V-Rotor system allows for a more compact, weight reducing rotor design and provides ultra-low start up inertia
  • Lightweight Air-Fin Spool Design
  • Rocket line management
    system provides better control of all types of fishing lines
  • Rocket spool lip design
    allows better control of line coming off the spool
  • AMG gearing system provides precision machined gears for unparalled smoothness and durability
  • Computer Optimized Gear design allows for the most efficient gear system
  • Carbon Matrix
    drag system provides smooth, consistent drag pressure across the entire drag range
  • Always on Instant Anti-Reverse
  • Mid arbor spool design
  • 6.2:1 gear ratio
  • Weight: 2500 – 5.5oz • 3000 – 5.7oz
  • MSRP: $399.95
  • Available: Now
The post Abu Garcia’s Premium Zenon MG-X Spinning Reel appeared first on OutdoorHub.
