An Air Weight Spinning Reel – Daiwa 2025 Luvias ST
Kevin
Senior Fisheman
Craig, Colorado
Best Catch
12lbs
Charger
Daiwa has brought out a new spinning reel that weighs about as much as a smartphone with the new 2025 Luvias ST. Coming in at 4.8 ounces for the 1000 and 2000 size reels, the Luvias ST (sensitive tune) might be one of the lightest spinning reels available. Made for ultra-finesse fishing applications, the Luvias has been tuned to be as smooth as possible. Available in three sizes, the 1000 and 2000 size reels are ideal for throwing small trout baits like small cranks and spoons. While the 2500 is perfect for anything from panfish to smallies and largemouths. All three sizes have an MSRP of $429.99 and are available now.
Fishing Coverage on OutdoorHub
Daiwa 2025 Luvias ST Spinning Reel Key Features
  • Zaion Monocoque Body – A single-component, high-density carbon fiber ZAION MQ body. Extremely lightweight, rigid, and durable.
  • Zaion Airdrive Rotor – A smart design that lessens weight, reduces vibrations, and evenly distributes stress. all the while maintaining strength.
  • Airdrive Bail – A hollow tubular steel bail that delivers maximum rigidity and strength with minimum weight.
  • Airdrive Shaft – Creates smooth, quiet rotation and provides anglers with enhanced torque and power
  • Airdrive Spool – Lessening weight, the AIRDRIVE Spool also improves oscillation, minimizes resistance during winding
  • Long Cast ABS – A two-stage spool design that reduces line friction, allows for a tighter line exit from the spool. and longer casts with fewer wind knots.
  • Tough Digigear – A7075 Aircraft Grade aluminum is forged into large, digitally-designed, and machine-cut gears with larger tooth patterns.
  • ATD (Advanced Tournament Drag) TYPE-L – Daiwa’s high-density woven carbon drag system now with a better initial drag response for improved drag use with lighter lines.
  • Machined Aluminum Screw-In Handle – A solid aluminum handle that screws directly into the reel body and main gear for better cranking power and durability.
  • Bearings – 2CRBB,6BB,1RB (1000, 2000), 3CRBB,6BB,1RB (2500)
  • Gear Ratio – 4.6:1 (1000), 5.7:1 (2000), 6.2:1 (2500)
  • Line Retrieve Per Crank – 22.6 in (1000), 29.4 in (2000), 34.3 in (2500)
  • Weight – 4.8 oz (1000, 2000), 5.3 oz (2500)
  • Mono Line Capacity – 2lb/130 yd (1000, 2000), 4lb/160 yd (2500)
  • Braid Line Capacity – 4lb/140 yd (1000, 2000), 6lb/220 yd (2500)
  • Max Drag – 6.6 lb (1000, 2000), 11 lb (2500)
  • MSRP – $429.99
  • Availability – Available Now
The post An Air Weight Spinning Reel – Daiwa 2025 Luvias ST appeared first on OutdoorHub.
