Daiwa 2025 Prorex MQ LT – Cold Cranking Power
DAIWA has brought out the new Prorex MQ LT for anglers looking for a top notch cold water spinning reel. Now featuring a ZAION V Monocoque Body, Daiwa’s advanced, proprietary, single-component body design. This is made from high-density carbon fiber to make an extremely lightweight, rigid, durable, and corrosion-resistant reel body. The design maximizes internal space to fight the larger Daiwa Tough Digigear drive train of the reel. Additionally, the new Prorex MQ LT comes with the AIRDRIVE reel system to reduce weight on the reel while improving strength, vibration control, and reel feel.
Designed with cold-weather anglers in mind, many of the features have been specifically made for just that. Such lower gear ratios for dealing with cold, thickened grease and slower cold water lure presentations. These reels are available in four sizes (2000, 2500, 3000, 4000) and have an MSRP of $219.99 to $229.99.
“There are design elements you can implement to make a reel perform better in temperatures below the 50-degree mark,” said DAIWA Field Marketing Manager, Chris Martin.
DAIWA 2025 Prorex MQ LT Key Features
  • ZAION V Monocoque Body– Daiwa’s exclusive compact frame design allows for maximum weight reduction.
  • Tough Digigear – A 7075 Aircraft Grade aluminum forged into large, digitally-designed and machine-cut gears with larger tooth patterns.
  • ZAION AIRDRIVE Rotor – A smart design rotor that reduces weight, improves stress distribution, and evens rotary balance.
  • AIRDRIVE BAIL
  • AIRDRIVE Shaft
  • AIRDRIVE Spool
  • AIRDRIVE ABS-Long Cast Spool
  • Type-L ATD Drag System
  • Machined Aluminum Screw-In Handle
  • Bearings – 1CRBB, 5BB, 1RB
  • Gear Ratio – 5.1:1 (2000), 6.2:1 (2500-XH), 5.2:1 (3000D-CXH, 4000D-C)
  • Line Retrieve Per Crank – 26.7″ (2000), 34.5″ (2500-XH), 30.6″ (3000D-CXH), 32.5″ (4000D-C)
  • Weight – 6 oz (2000), 6.5 oz (2500-XH), 6.9 oz (3000D-CXH), 7.8 oz (4000D-C)
  • Fluoro Line Capacity – 4/160 (2000), 6/160 (2500-XH), 10/280 (3000D-CXH), 10/360 (4000D-C)
  • Braid Line Capacity – 6/220 (2000), 8/200 (2500-XH), 15/250 (3000D-CXH), 20/280 (4000D-C)
  • Max Drag – 11 lb (2000), 22 lb (2500-XH), 22 lb (3000D-CXH), 26.4 lb (4000D-C)
  • MSRP – $219.99 – $229.99
  • Availability – October 2025
The post Daiwa 2025 Prorex MQ LT – Cold Cranking Power appeared first on OutdoorHub.
