NEW PENN Wrath II Reel and Combo – Affordable Option
Equipping anglers worldwide since 1932, PENN knows something about making fishing reels. From tried and true offshore conventional classics like the Senator and International lines to inshore spinning reels like the Battle and Spinnfisher lines. Now PENN is introducing the new Wrath II spinning reel and combo to their long list of fishing gear. Designed to be tough and affordable, this new budget-friendly Wrath II reel has a lightweight design that is loaded with user-friendly features to make it a great choice for anglers of all ages and experience levels.
The body of the reel is made of corrosion-resistant material. The spool of the reel is machined out of aluminum and then anodized for a tough and corrosion-resistant black finish. Add to these two features the 2+1 shielded stainless steel bearings and you have a reel that can survive salt exposure without being eaten up by the salt. The Wrath II spinning reel is available now with sizes starting at 2500 and going all the way up to 8000. MSRP for just the reels ranges from $49.99-$69.99. The Wrath II Rod and Reel combo is also available now in a variety of sizes from a 6’6″ medium light combo all the way up to a 12′ heavy surf combo. MSRP for the combos starts at $69.99 and goes up to $119.99 for the largest models.
PENN Wrath II Reel Key Features
Penn Wrath II Combo Key Features
The post NEW PENN Wrath II Reel and Combo – Affordable Option appeared first on OutdoorHub.
- Lightweight and Corrosion-resistant graphite body
- 2 Shielded Stainless Steel Ball Bearings
- Instant Anti-Reverse Bearing
- Machined and Anodized Aluminum Spool
- Line Capacity Rings
- Classic PENN Cosmetic
- Models: WRTHII2500 • WRTHII3000 • WRTHII4000 • WRTHII5000 • WRTHII6000 • WRTHII8000
- MSRP: $49.99-69.99
- Available: Now
- PENN Dura-Guides
- Lightweight and corrosion-resistant body
- EVA Grips
- Two-Piece composite blank
- New Combo – 12 Ft. Surf Model
- Models: WRTHII2500612S662ML • WRTHII3000612S702ML • WRTHII40001017S702M • WRTHII50001220S702MH • WRTHII50001225S802MH • WRTHII60001530S902MH • WRTHII80002040S102H • WRTHII80002040S122H
- MSRP: $69.99-119.99
- Available: Now
