New Premium Long Nose Pliers from Toit Fishing
While Toit Fishing is a relative newcomer to the fishing tool market, they have started out on the right foot with innovative reimagined fishing tools that focus on reliability, functionality, and durability. All the while they don’t skimp on the form and design of the too along with environmental sustainability. In their goal to make products that are meant to last and can resist corrosion and time, they use premium materials as well skipping over superfluous plastic parts that will breakdown and wear out quickly over the lifetime of the products. Made to work well and feel good in the hand but still pleasing to the eye, the NEW Long Nose Pliers from Toit are sure to be an amazing addition to the discerning angler’s tackle box.
Photo Courtesy of Toit Fishing
The new longnose pliers have been meticulously designed to work around a fish’s gills without damaging them, giving the user great finesse and control when removing hooks that landed in tender and delicate spots. The tips of the pliers have been fully polished so no sharp edges to worry about. The jaws of the pliers are shorter to provide better-grabbing force and rigidity when you really have to give it some beans to torque a hook out. The short jaw length also gives a smaller fulcrum distance preventing any side-to-side twisting and play, the bane of good fishing pliers. The length of these pliers is instead in the handle giving you ample hand space where it counts. The unique handle design also allows the pliers to get into tight spots and odd anglers you often find yourself in. The long nose pliers are spring-loaded for easy repeated use and come in just over 9″ in overall length. The new Toit Long Nose Pliers provide the angler with the perfect balance between form and function.
The post New Premium Long Nose Pliers from Toit Fishing appeared first on OutdoorHub.
Specifications
- 9″ Stainless Steel 410 J1 Drop Forging
- Optimal length to prevent deforming
- Serrated teeth
- Internally spring loaded for easy operation
- PVD Tialn surface coating
- Ergonomic hand finished design
- Designed for hand/grip comfort
- Lightweight
- Designed to fit the Rigid Toit Holders available in Black or White (Sold Separately)
- Environmentally friendly product, no rubber/plastic/silicone handle
- All metal design – No plastic to fall off, shrink or get damaged
- Highly polished surface finish
- Important….rinse, wipe clean, lightly oil for smooth operation after use.
