Shimano’s NEW 2025 10K and 14K Stella SW D Spinning Reel
Shimano North America Fishing is raising the bar on saltwater spinning reels once again with the new 2025 2025 10K and 14K Stella SW D. Aiming to make the ultimate saltwater spinning reel for fighting and landing the biggest gamefish, the new Stella SW D is crammed full of features designed for offshore anglers who demand peak performance. At the heart of the reel is the Shimano cold-forged HAGANE Gear, which features InfinityXross technology. This gearing system distributes the load evenly across each gear tooth for unmatched durability and smoothness.
“The Stella SW D is designed for serious saltwater anglers chasing giant tuna and other powerful species that test the limits of gear and angler alike,” said Blaine Anderson, Shimano Saltwater Marketing Manager. “This reel delivers a combination of cutting-edge technologies and durability that will give anglers the confidence to push their limits and conquer the impossible.”
These spinning reels debut the new XX Tough Drag system, a large drag washer design, and an advanced heat dissipation system that ensures peerless drag durability and smoothness during long, intense battles with big fish. Complementing the tough drag is the new Heatsink Drag, which pulls heat from the spool to minimize heat transfer to the line during long fights. This ensures better line strength and longevity. Along with those new features, the reels also come with InfinityLoop tech, the Anti-Twist Fin, X-Protect, and many more. These features make this reel one of the toughest fishing reels available. MSRP for both reel sizes is $1100 and should be available from Shimano dealers later this year.
Shimano 2025 Stella SW D Spinning Reel Key Features
The post Shimano’s NEW 2025 10K and 14K Stella SW D Spinning Reel appeared first on OutdoorHub.
- InfinityXross – Extends the cold-pressed HAGANE gear tooth surface
- InfinityDrive – Smooth, effortless winding — even under heavy load
- Heatsink Drag – A heatsink structure on the bottom of the spool to help dissipate 50% of heat outside the spool to reduce drag-force drop due to heat during long fights.
- XX Tough Drag – The drag washers have significantly increased in size, and the upper drag washer has moved to the top of the spool to increase drag durability and have less heat accumulation.
- Anti-Twist Fin – Ensures even line lay on the spool and minimizes the occurrence of wind knots.
- Hagane Gear – Cold-forged, extremely durable, and wear-resistant alloy from Shimano
- X-Protect – Aids in preventing water from entering internal structures and helps reduce the risk of corrosion
- Ball Bearings – 12 + 1 Ball Bearings
- Reel Sizes – 10000, 14000
- Line Retrieve Per Crank – 39in, 53in
- Gear Ratio – 4.8:1, 6.2:1,
- Weight – 24oz, 24.2
- Max Drag – 55lb for both sizes
- PowerPro Braid Line Cap (lb – yd) – [50-360, 65-290, 80-215], [50-400, 65-315, 80-240]
- MSRP – $1,100
