The Beachwalker Surf Rods NEW from Blackfin Rods
Renowned Florida-based rod makers Blackfin Rods have announced their latest new innovation in surf rods. The new Beachwalker Surf Rod is packed with cutting-edge technology and built with unparalleled craftsmanship to deliver an exceptional surf fishing experience for all anglers. These new Beachwalker surf spinning rods come in two sizes, a 10ft and 12 ft rod. The 10ft rod is a Medium Heavy rod with fast action, rated for line in the 12-25lb range and lures in the 3-8oz weights. The 12ft rod is a Heavy rod with fast action, rated for line in the 17-30lb range and lures in the 3-10oz weights. Both of these Blackfin Beachwalker Surf Series rods are two-piece spinning rods great for easy transportation. They are built for anglers of all skill levels, from veteran surf anglers throwing tins in foul weather to beginners who are just dipping their toes into surf fishing for the first time.
The Blackfin Beachwalker Surf Rods use high-quality K-frame line guides, which help fight against wind knots and increase the angler’s casting distance. The 2 piece blanks are made of a high-modulus 30T carbon fiber. This is matched with a special resin to make the blanks much lighter, slimmer, and more powerful. X cross 45 degrees carbon technology is also used in the blanks to increase the toughness and strength of the blank all the while eliminating blank twist. The rod grips are made of a unique X-wrap rubber thermal heat shrink for excellent grip even if your hands are wet or slimy. MSRP for the rods is $209.99 for the 10ft rod and $219.99 for the 12ft rod, both models are available for purchase now from either Blackfin Rods or Blackfin Rods dealers.
Blackfin Beachwalker Surf Rods Key Features:
The post The Beachwalker Surf Rods NEW from Blackfin Rods appeared first on OutdoorHub.
- K-Frame Guides – To help elimnate wind knots and increase casting distance
- High Modulus 30T Carbon Fiber Blank – A lighter, slimmer, and more powerful blank that uses a special resin and X-Cross 45 degree carbon technology for increased toughness
- Unique X-wrap Rubber Heat Shrink Grip – Stays grippy when wet
- Two Models, 10′ and 12′ Beachwalker Surf Spinning Rod.
- 10’ Medium Heavy Fast Action, Line wt. 12-25 lbs., Lure wt. 3-8 oz
- 12’ Heavy Fast Action, Line wt. 17-30 lbs., Lure wt. 3-10 oz
- MSRP $209.99 – $219.99
- Available Now at your local Blackfin Rods dealer or on the Blackfin Rods website
